Corolla Hybrid?
Discussion in 'Toyota Hybrids and EVs' started by stephensprius, Oct 2, 2017.
  1. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    Do you think a Corolla hybrid sedan/Hatchback will ever make it to the US?
  2. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    There's two scenarios in which I could see it happening under the Corolla nameplate. (I phrase it like that because the CT 200h basically is a Corolla iM (hatchback) hybrid, and the Prius Liftback is rather close to a Corolla sedan hybrid in role.)
    The first scenario is if the Gen 5 Prius no longer has a non-plug-in model - basically, the Prime being the only model of Prius. In that case, I could see the hybrid powertrain being made an option on the Corolla line.
    The second scenario is if import duties on Japanese cars are raised. In that case, Prius volume to the US market likely is too low to justify local production, so the Corolla sedan would likely get a hybrid powertrain instead, just like how it gets one in the Chinese market where import duties are currently too high on Japanese cars for the Prius to be viable (and in fact, the Gen 4 is not sold there). Conversely, in the European market, the Auris (Corolla iM) has a hybrid variant that's cheaper than and more popular than the Prius, but as it's also smaller than the Prius, there's still a niche for the Prius (especially as a taxi) in that market.
  3. Prodigyplace
    12,718
    11,850
    Central Virginia
    The Gen 4 Prius is larger inside than the Corolla. I think it is closer to the Camry.
    I bought a Prius instead of a Corolla after realizing we needed more inside space than our 2008 Corolla for a pending dog purchase. We tested the crate in the Corolla and found it lacking, compared to the Prius.
  4. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    The cargo configuration of the Prius is better, but the current (2014+) Corolla sedan got bigger, and is similar in size to the Gen 3 Prius that it's closely related to.
  5. bisco
    52,876
    not until gas prices go up.
  6. Tideland Prius
    16,683
    I like @bhtooefr's explanation. It sounds logical to me. An Auris Touring Sports would be fantastic but I know they won't import a Corolla wagon. (The Corolla iM is the Auris hatchback). A Corolla already gets pretty good mileage (I've seen 50mpg at a steady 50mph in the 2014 version that I drove). Perhaps we'll see a PHEV version which would give a much greater mileage gain compared to a hybrid. (Yes I'm aware I was quoting a highway number. My city number for that car is 32.7mpg so it could be improved to 45mpg or 50mpg city)
  7. Prodigyplace
    12,718
    11,850
    Central Virginia
    That is much better than my 2008 Corolla.
  8. Tideland Prius
    16,683
    Benefits of a CVT. The 2008 would've had a 4-speed auto (still can't believe Toyota left it that way)
  9. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Toyota is usually extremely conservative, after all - hence the US Corolla's engine lineup being all 1.8 liter 4-cylinders (although Valvematic is a surprising one for them to try in the US market) with port injection and no turbos. The 4-speed automatics have been quite reliable and are likely cheap to make, and they didn't need much more to meet fuel economy standards of the time, so why do better?
  10. Tideland Prius
    16,683
    Because they should? lol. But yeah from an accountant's perspective - if the 4AT meets mpg requirements, emissions requirements and it's dirt cheap to install (hence a lower MSRP), why not? Recall even the 8th gen had optional 3A or 4A for CE models (depending on your budget). Canadian models all had optional 4A (standard on LE in 2000-2002)
  11. Trollbait
    12,832
    The Toyota Yaris still has a 4 spd auto.
  12. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    That's partially because it's a class of car that sells very poorly, and buyers of it care about minimum purchase price above all else, even efficiency. I mean, the Fiesta is being discontinued in the US because we don't buy enough of them to even bother bringing the new generation - I wouldn't be surprised if we lose the Yaris entirely (except for maybe the Yaris iA, seeing as it's actually a rebadged Mazda2) when the Yaris actually moves to TNGA, especially because the US is currently getting French-built Yarises - that plant won't want to stay on old Yaris production.
    The US/Canadian-spec car has an entire automatic powertrain that dates back to 1999, in the 2000 Echo - the 1NZ-FE and U340E (and, the 1NZ family dates back to 1997, with the NHW10 Prius).
    Conversely, a new automatic 1.5 liter Yaris in Europe has the much newer, more efficient 2NR-FKE (a family from 2008, a variant from 2015), with I believe the K411 CVT (from 2010). (The base engine is the 1KR-FE, but that's a 1.0 liter 3-cylinder, designed by Daihatsu, that we'd never get, and is manual only, and the other choice is the 1NZ-FXE and P510 that we get in the Prius c.) That's because that's a class that actually sells well there, and warrants investment.
  13. bisco
    52,876
    i was wr, wro, wrong :oops:
  14. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
  15. Tideland Prius
    16,683
    Prodigyplace likes this.
