Corolla/Matrix suspension compatibility
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Erik Martini, Sep 23, 2019.
  1. Erik Martini
    Erik Martini New Member
    Los Angeles
    I was recently looking in to changing the suspension on my 2004 Prius to adjustable coil overs, most likely the Megan racing coil overs. However, after looking around on this forum I’ve been wondering if the aftermarket coil overs for the corolla/ matrix will fit. There are a lot more options for the Corolla/matrix then for the Prius.
    I’ve noticed that many on here have eluded to the components working ie sway bars, but what of the struts themselves?
    Also if it is possible has anyone tried it?
  2. caravan2429
    caravan2429 Junior Member
    64
    Sandy, UT
    I think it should be similar or even the same. Only difference is spring rate and shock setting.
    Landon51 likes this.
  3. Erik Martini
    Los Angeles
    Fair enough, the Corolla coil overs are significantly cheaper than anything I’ve found for the Prius so I’m concerned that no has tried this out. I did notice that the oem part numbers for the struts are in fact different, so that does concern me a little. I would still love to find someone that has tried to fit a Corolla strut into a Prius.
  4. Landon51
    Landon51 Member
    190
    63
    US
    If you're in the San Fran Bay area, ill go to a salvage yard with you and we can test that hypothesis out 8)
    SFO likes this.
  5. Erik Martini
    Los Angeles
    If I had the time I'd do that myself, trying to even find time to do research is hard enough. I did notice in a post by member prius70 untitled "going lower...inserts" he mentions in passing about using corolla struts and how smooth they are, the fact that he can push down on the front end and have it come back up. Something along those lines. It was such a brief mention that I missed it a few times I read through.
    So with that single reference I might just have to bite the bullet and order some corolla lowering coilovers and hope they work out with little to no modification.
    SFO likes this.
  6. caravan2429
    64
    Sandy, UT
    Sometimes different part numbers don't really mean the compatibility. Just a kind of classification to be easily found.
  7. Erik Martini
    Los Angeles
    Good point, I’ve studied the various pictures of both struts and they do look rather similar. If I do end up getting the Corolla suspension I’ll be sure to post any updates.
  8. caravan2429
    64
    Sandy, UT
    From my information, gen 2 Prius platform shares with Corolla but with some modifications. Front and rear suspension parts are essentially the same as Corollas but with different settings. For example, diameters of sway bars, different spring rates and shock hardness. on Prius, for the purpose of weight distribution and ride quality. Toyota engineers made some changes on it but generally speaking, if you are not expert in the area, you can not find significant or even slight difference between them. They should be compatible.
    NortTexSalv04Prius likes this.
  9. Erik Martini
    Los Angeles
    Thank you very much caravan, at least now I’m more confident in purchasing the coil overs. If I do get them, like I said, I’ll post the results here.
  10. Freefall Prius
    Freefall Prius New Member
    Brevard County, FL
    Eric, did you ever get a chance to continue digging on the Corolla suspension items and if they will fit your Gen 2? I'm in the same boat and searching for answers on suspension upgrades.
  11. Erik Martini
    Los Angeles
    I'm afraid not freefall, I did just talk to my mechanic today in regards to the suspension compatability, he said that they are very similar but there are subtle changes to the coils and spring rates. But when pressed about if they would mount with all the existing bolt holes he was unsure. So I'm still in the same boat, I'm leaning towards just biting the bullet and getting the corolla suspension and trying it.
  12. Freefall Prius
    Brevard County, FL
    Erik, I wrote another reply earlier today in response to a thread about Suspension Upgrades. You should be able to find it with a quick search.
    There are so many good posts here from the past, it can be overwhelming. But, several years ago, Justdidit really tricked out his Gen 2 and used Bilstein Shocks and Struts (Bilstein B8 Series for an 03 to 08 Corolla). He took great picks and also posted part numbers.
    The only difference is he was interested in lowering his Prius (and did an awesome job). But I'm interested in raising my car an inch or so for better ground clearance and still want to upgrade with a quality suspension system. Type in Bilstein and you should be able to find that 2 or 3 year old thread.
    Whoever designed this site really deserves a big thanks bc it is very easy to find information (if it's contained in a prior thread).
  13. strawbrad
    953
    999
    The Corolla struts will not fit a Prius. I spent a bunch of time in a you pull it junkyard yard trying to figure this out. The mount to the steering knuckle is where the parts differ.
    I have found a solution for lifting and stiffening a Prius.
    Heavy Springs And Lift Upgrade | PriusChat
  14. Freefall Prius
    Brevard County, FL
    Very interesting. Heading over to your other post to read up.
  15. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    I just want to verify that you are stating that the front wheel knuckles on Toyota Corolla 2003-2009 model year are different geometry than Toyota Prius Gen 2 model year 2004-09.
    Kaptainkid1 likes this.
  16. strawbrad
    953
    999
    Yes,
    The mounting surface for the strut are different thickness.
  17. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    but will the rear corolla struts bolt in?
  18. strawbrad
    953
    999
    Maybe?
    I did not compare the rear struts when I was at the U Pull It yard. Looking at Rock Auto's spec shows they are very similar.
    Another option to look at would be springs from a 2005 or 2006 Corolla XRS. This was a sporty version those springs might firm up the suspension without raising or lowering a Prius.
  19. Moerice
    Moerice New Member
    Fresno, CA
    Will the AWD matrix 2009 complete rear shock fit the 2009 Prius? Your thread is about the Prius rear shock modified using matrix spring, the top is the same for both, but is the bottom bolts thickness the same? You would know, you had both in possession.
  20. Tombukt2
    Tombukt2 Senior Member
    9,131
    1,585
    Durham NC
    Bingo the Matrix XR4 or some such. I was looking in a parking lot the other day with my Prius pulled right up alongside this matrix XR4 I think it is all wheel drive sits a good 1.7 in higher than my Prius and all the mount points look to be exactly the same I can't imagine weight would be humongously different to change the suspension all that much so I'm probably going to order a set of middle of the road set up or maybe coilovers but I doubt it I would rather have the larger diameter variable rate springs I think but it should do nicely as far as the lift goes without any of the hub bub . Or expensive aftermarket parts unless you really want to go higher.
