Corolla to Prius gas tank swap
Discussion in 'Gen 2 Prius Technical Discussion' started by Rivieraman71, Mar 3, 2019.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    FYI
    semi drop on Corolla fuel tank
    audiodave likes this.
  2. Rivieraman71
    Rivieraman71 Active Member
    148
    195
    Englewood, FL
    Thanks for the video! Was watching it when I researching the swap and definitely helped a lot on the decision to do the swap.
    NortTexSalv04Prius likes this.
  3. NortTexSalv04Prius
    915
    115
    Hey I also found the following YouTube post semi drop of a Gen 3 Prius fuel tank wondering (curious) if that could be adapted to a Gen 2
  4. Rivieraman71
    148
    195
    Englewood, FL
    I was looking at a 3rd gen swap too and I think the corolla will be more straightforward. It’s pretty much plug and play with just a few emissions hoses being rerouted.
  5. terramir
    terramir Member
    318
    51
    Los Angeles
    I have always thought it was a pain in the arse to fill the prius tank, however I get my tank full the most I ever put in it is about 11.5-11.6g myself so I was running on fumes basically. I have to top off the last gallon to gallon and a half but I get the tank full maybe my bladder is just stretched so far that it dun matter it's 16 years old after all (reg 1st 10/2003). but A tank with a 13+ gal capacity where I dun have to top off the last gallon to 1 1/2 gal would be cool.
    terramir
  6. Rivieraman71
    148
    195
    Englewood, FL
    Went to the junkyard and got everything I need for the gas tank swap. They were having a 50% off sale today and walked away with everything for $59 out the door.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Out of curiosity, is it at all possible to just remove the bladder through an opening? Perhaps remove any components from the top of the tank and just cut it out?
  8. Rivieraman71
    148
    195
    Englewood, FL
    You have to cut the tank open to remove the bladder. I wish it was that simple. Took me about 2 hrs to get everything out at the yard.
  9. padroo
    padroo Senior Member
    2,763
    2,252
    Working under a car at a junk yard sucks. I feel for you.:cry:
    Raytheeagle likes this.
  10. Rivieraman71
    148
    195
    Englewood, FL
    All I thought was “I hope this car doesn’t fall and kill me” lol
    Raytheeagle and bisco like this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Hopefully it had more than a couple of steelies holding it up;).
    Otherwise I hope the straps weren’t too tight causing you to have to torque on it(y).
  12. Rivieraman71
    148
    195
    Englewood, FL
    2 steelies holding the front and 1 holding the back. It was a little nerve racking breaking bolts loose underneath.
  13. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    You’re a brave man;).
    Or maybe just desperate :cool:.
    But at least you lived to tell the tale(y).
  14. Rivieraman71
    148
    195
    Englewood, FL
    A little bit of both lol
    chelvis and Raytheeagle like this.
  15. Rivieraman71
    148
    195
    Englewood, FL
    726B229C-B6FC-4669-AAC7-E20D1073262F.jpeg So plans have changed on the corolla gas tank swap. It’s now going to be a Camry tank going into the Prius. Why bump up to a 13.2 gallon tank when you can go all out and have a 18.5 gallon tank in a Prius! Went back to the junkyard and dropped the tank in a 2007 Prius and a 2005 Camry. Shoved the Camry tank in there and it’s gonna need a little persuasion with a block of wood and a hammer but it’s pretty close to fitting in there. Here’s a pic after putting the Camry tank in place of the Prius tank. Now mind you there are no straps holding it in it’s just wedged in there. It has about a good 3 inches of space above it that it needs to go up and and inch or 2 forward. Will have a 900 mile range after the swap is done. And can you say no more pain in the rear bladder?
    #75 Rivieraman71, Apr 23, 2019
  16. padroo
    2,763
    2,252
    I always hated a weak bladder.:D
    Good luck on your project and be safe under those old cars.
  17. Rivieraman71
    148
    195
    Englewood, FL
    Thanks, safety first! Going back tomorrow to grab the tank.
  18. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    This is where I'm confused. I've always thought fuel tanks were designed for specific car bodies due to fit and form to ensure the tank top matches the contours of the car floor. How can there not be significant interference issues between the top components and places on the car body? What do you do if a high pressure fuel supply line or return line rubs on the car body and eventually springs a leak? I guess I'm just not getting 'it'. Or do you just jam it up there and crank down on the straps and assume it's all good? Then it's just a matter of keeping your fingers crossed that it doesn't fireball at some point?
    Why not just cut open a Prius tank and remove the bladder if desired. Find another tank and cut a 2 or 3 inch strip from the circumference and weld it onto the first tank. Now the tank would be 2 or 3 inches deeper, but would still have the OEM top components and shape.
    Hell, idk what I would do with that kind of range anyway. Gotta stop for snacks and restroom breaks anyway...
  19. Rivieraman71
    148
    195
    Englewood, FL
    The contours of the top of both tanks is very similar. The tank shape allows for the fuel lines to be safely routed on top of the tank. When I dropped the Prius tank I looked to see what sat on top of the tank and took that into consideration. I definitely wouldn’t just bolt it in and hope it worked. I’m aiming to make it look like a factory job. If it doesn’t work I have the corolla tank that will fit with no modifications to the tank itself. It’s pretty much a challenge to see if it can be done and help others that might want to tackle the same project.
    SFO likes this.
  20. Rivieraman71
    148
    195
    Englewood, FL
    CC22765B-4292-4376-BEF0-DA87025729C4.jpeg C4ACD232-C3FB-43A4-BE41-D054D38C264E.jpeg View attachment 169987
    The contours of the tanks are almost the same on top. The Electrical connection for the Prius sending unit and the sending unit on the Camry tank line up in the same spot at the access hole under the seat.
    #80 Rivieraman71, Apr 23, 2019
    SFO likes this.
