Corolla to Prius gas tank swap
Discussion in 'Gen 2 Prius Technical Discussion' started by Rivieraman71, Mar 3, 2019.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    So Camry to Corolla to.....still loving it
  2. Rivieraman71
    Rivieraman71 Active Member
    148
    195
    Englewood, FL
    Thanks, I figured I’d go all out on this!
    NortTexSalv04Prius likes this.
  3. Rivieraman71
    148
    195
    Englewood, FL
    1B20D9CE-A3C6-44B3-860C-30412C2D9EE7.jpeg Corolla tank on the left 13.2 gallons. 660 mile range
    Camry tank on the right 18.5 gallons 925 mile range
    Richard Pérez likes this.
  4. Rivieraman71
    148
    195
    Englewood, FL
    Well the plans for the Camry tank are getting scrapped. Decided to go with the corolla tank instead. The corners of the Camry tank would need to be beat to death with a hammer for enough clearance to fit and plus the tank covers the bolt holes for the mounting straps. So pretty much I would have to drill holes to make new mounts for the straps and I’m not gonna do that. Also I would have to cut the exhaust after the resonator and mount a new muffler in the tunnel under the center console cause there would be absolutely no room to run the exhaust to the back. Soo if you’re deciding to take on this project like I am just go with the 9th gen Corolla tank and not the Camry.
    San_Carlos_Jeff, SFO, chelvis and 2 others like this.
  5. Rivieraman71
    148
    195
    Englewood, FL
    BF1EA94A-4D67-4060-AAA4-EFD024B5817B.jpeg Wanted to add this as a reference. This is the stock Prius tank with all the emissions still attached to it.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    The rubber pads are where the tank makes physical contact with the car body?
  7. Rivieraman71
    148
    195
    Englewood, FL
    Yes, the corolla tank makes the same contact points.
    correct!
  8. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Have you read this thread?
    the gas bladder: exposed! | PriusChat
    I no longer have any desire, at all, to pull the gas tank from my spare parts car to experiment with the fuel tank.
    There's a lot more to it than I imagined.
    #88 TMR-JWAP, Apr 27, 2019
  9. Rivieraman71
    148
    195
    Englewood, FL
    what year make and model is your parts car? I’ve read that thread. Don’t let those pics of the bladder tank intimidate you.
    #89 Rivieraman71, Apr 27, 2019
  10. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    2007 loaded to the gills
  11. Rivieraman71
    148
    195
    Englewood, FL
    Well if you seriously want to swap your tank for a bladderless one you’ll need tank, sending unit, filler neck, straps and charcoal canister out of a 2003-2008 corolla to be a bolt in swap. Also if you can get your hands on the electrical harness inside the Prius tank it will be a complete plug and play from what I see. The Prius harness has a temperature sensor that makes the gas gauge accurate. You’ll have to cut a second gen gas tank open to get the harness. I got one out of the junkyard and used tin snips.
    SFO and NortTexSalv04Prius like this.
  12. Rivieraman71
    148
    195
    Englewood, FL
    This is what you will need to do the swap. I still need to go back to the yard and get the exhaust heat shield for the tank.
    #92 Rivieraman71, Apr 27, 2019
    SFO and chelvis like this.
  13. NortTexSalv04Prius
    915
    115
    River A Man
    So Now that you are going with Corolla tank
    I am curious if you checked to see if the Matrix/Vibe/Prius C fuel systems may have been similar to that Corolla. ?(Which model Year did you use)
    Are you(could you) going to use wire harness from the pulled Gen2 tank that you stated earlier? Image maybe?
    Does the access panel align with the Corolla tank? and does the filler neck tube /evap tube next to that are they more flexible than prius Gen2? I am also thinking you will replace fuel pump/sending unit on Corolla tank
    Thank you for your thread/posts
    #93 NortTexSalv04Prius, May 3, 2019
  14. NortTexSalv04Prius
    915
    115
    Almost forgot to ask and not to overstate obvious However Gen2 Prius tank ...heavier and less capacity Corolla possible less weight, little more capacity , easier to manhandle, no metal tank shield shrouding plastic bladder.
    thanks
  15. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    No matter how much I'd like to see this work out, I just can't bring myself to believe this is going to be a fault free, aesthetically pleasing swap. I see permanent CELs, or a bunch of jerry-rigs to try to fake out the ecu. I'm not fond of "1/2 donkeying" fuel tank systems. Nothing like always wondering if you're one surprise pothole or fender-bender away from doom.
  16. Rivieraman71
    148
    195
    Englewood, FL
    The Matrix/corolla and vibe use the same emissions and gas tanks. I looked up the Prius c tank and it doesn’t look like it will work at all. The contact point on the body are totally different also.
    I got everything I needed out of a 2005 Corolla.
    Correct I am going to use the wiring harness that I cut out of the 2nd gen tank to make it a clean plug and play swap. All the emission sensors on the Corolla are the same as the Prius so the emissions wiring harness from the Prius can plug into everything on the Corolla charcoal canister.
    The location of the corolla tank and access hole on the Prius are off by a few inches but the location of the corolla tanks fuel pump fits in the raised tunnel of the Prius under the seat.
    The filler tube on the Prius is a metal flex tube and the corolla is a pre bent rubber hose. If you look at the drivers side wheel well on your Prius there is a notch cut out on the bottom front that is also in the same location on the Corolla and that’s where the filler tube goes through on the Corolla.
    I’m going to use the stock Corolla sending unit because it’s calibrated to the depth of the Corolla tank to give an accurate reading for the gas gauge. Plus the harness that I cut out of the 2nd gen tank is a direct plug in for the Corolla fuel pump. Both the Prius fuel pump and the Corolla share the same 4 pin connector.
    #96 Rivieraman71, May 4, 2019
    NortTexSalv04Prius and SFO like this.
  17. Rivieraman71
    148
    195
    Englewood, FL
    96137A24-4805-484C-9BE1-B7CB15A5CDEF.jpeg AD99DC1D-37B0-4C74-B3F1-F11CCAE666CD.jpeg C834DE04-194C-464C-8CB0-F2661A15B47F.jpeg D7E651BB-1B87-4DF8-AFDD-F224210020A6.jpeg
    This is the harness I pulled out it the 2nd gen tank. Left side is the main plug for the harness, top right plug is for the fuel pump and bottom right plug is the temperature sensor. Plugs right into the Corolla fuel pump.
  18. Rivieraman71
    148
    195
    Englewood, FL
    The Prius tank is definitely a lot heavier than the Corolla tank. The Corolla tank holds 1.3 gallons more than the Prius tank but is physically smaller. The Corolla tank is bladder-less, correct and plastic instead of metal.
    NortTexSalv04Prius, audiodave and SFO like this.
  19. bluejets1
    bluejets1 New Member
    brownwood ,texas
    talking about swapping ,I want to put a 1.8 Prius in an 07 Corolla. any ideals
  20. NortTexSalv04Prius
    915
    115
    River A Man
    IDK I do not know if this will help you However when you road test and you possible get Evap codes continue to drive my past experience is they will likely go away.... Additionally when you get on the road let us know how possible your first or second tank of fuel fill up went. Thanks again and enjoy the journey
