Corolla to Prius gas tank swap
Discussion in 'Gen 2 Prius Technical Discussion' started by Rivieraman71, Mar 3, 2019.
  1. Rivieraman71
    Rivieraman71 Active Member
    148
    195
    Englewood, FL
    I was gonna say if it the swap throws a code or codes as long as the car runs and drives as it should and gets the same mpg it wouldn’t bother me. I don’t have vehicle inspections where I live so an engine code wouldn’t be an issue. I should have another 70 miles out of a tank with the swap. I appreciate the positivity on the swap. Looking forward to the project. Should be underway in the next few weeks.
    #101 Rivieraman71, May 7, 2019
  2. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Mr River A Man
    Would offer you free helping hand (forget that commute though) I am hoping for success on your project
  3. Rivieraman71
    148
    195
    Englewood, FL
    That would be a very long commute! Have someone that wants to trade a corolla for my truck so once I have another car the tank swap can get started.
    NortTexSalv04Prius likes this.
  4. PAUL SCHULTZ
    PAUL SCHULTZ Member
    103
    66
    Michigan
    Any update on this project?
  5. NortTexSalv04Prius
    915
    115
    I believe this is still a work in progress ..I am also optimistic that OP completion will have a rewarding/successful outcome.
    Raytheeagle likes this.
  6. Rivieraman71
    148
    195
    Englewood, FL
    So an update I just bought another car so I’m hoping pretty soon I’ll start on the tank swap.
  7. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    There is a valve on every car that when it goes bad it won't let you fill tank. When I remember what it is called I'll post
  8. Raphael Muscarelle
    661
    222
  9. Rivieraman71
    148
    195
    Englewood, FL
    The problem is the actual bladder inside the tank
  10. NortTexSalv04Prius
    915
    115
    There is a thread which has a teardown of a Gen2 Fuel Tank taken apart from the Evap system.(when you state valve/show link or image)
    FYI
    Gen2 Fuel system
    Metal filler neck w/evap hose
    Metal Case Fuel Tank
    Plastic Bladder
    Fuel pump inside bladder
    Evap charcoal canister and lines on top of fuel tank
  11. NortTexSalv04Prius
    915
    115
  12. Prodigyplace
    12,526
    11,747
    Central Virginia
    The Gen 4 has a valve that seals off the filler neck after 30 minutes or if the fuel door is closed.
  13. Raphael Muscarelle
    661
    222
    The valve I'm referring to is usually in the carbon filter.
    When a gas tank is being filled it displaces atmosphere. If this valve is closed when fueling it kicks off the fueling like the tank is full.
  14. Raphael Muscarelle
    661
    222
  15. Rivieraman71
    148
    195
    Englewood, FL
    I know which valve you’re referring too. Since the weather has heated up in Florida I haven’t had any problems filling the tank it’s only when the weather is cooler. The rubber bladder gets stiff and doesn’t like to expand. Plus I want to swap to the Corolla tank because it would give me a longer range between fill ups.
    audiodave and Prodigyplace like this.
  16. Raphael Muscarelle
    661
    222
  17. Raphael Muscarelle
    661
    222
    More likely the solenoid in the valve has a hard time operating in the cooler temp
  18. NortTexSalv04Prius
    915
    115
    Plastic bladder in Gen2 has minimal contraction in sub 32F weather and vice versa in hot Texas summer.
  19. NortTexSalv04Prius
    915
    115
    any image post you can show us
  20. NortTexSalv04Prius
    915
    115
    Gen2 Technical Thread
