Correct me if I'm wrong... (new Gen1 owner)
Discussion in 'Generation 1 Prius Discussion' started by S Keith, Sep 11, 2015.
  1. S Keith
    S Keith Senior Member
    799
    330
    AZ
    2003 Prius
    LOL... good one. You're so right. At least with the Civics, I developed a very reliable method for identifying bad modules.
    My expectations are very low. I'll gnaw my way through this pack and see what I get.
    bwilson4web likes this.
  2. S Keith
    799
    330
    AZ
    2003 Prius
    Still working to get the pack cleaned up. Bus bars are stubborn. A little soak in some sulfuric acid followed by a de-funking and buff with wire brush gets them pretty clean.
    There is a sticky brown substance that looks deliberate along the top of the bus bar plastic retainer strips that is on many of the nuts and bus bars. Is this an adhesive?
    Preliminary results are very discouraging. Trickle charges (50-350mA) of individual modules to > 7V typically results in either an inability to retain voltage or a run into the 8V range. 8V under such a low current with only a couple hundred mAh input is indicative of very high internal resistance.
    I did a 1C forming charge and 1A discharge of #38 (6.74V). I let a full 24 hours lapse between charge and discharge, and it was only about 1800mAh. I'll cycle it a few times and see if I get any improvement.
    Otherwise, the plan is the same... I'll do a grid charge to peak voltage and see what I get on module discharge. Already looking for replacement packs.
    Steve
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    I've been in your position before and it looks like you have a fun project on your hands.
    Older Prius batteries can be pretty fickle. I've messed them far more than I'd like to admit.
    Prius batteries definitely do not behave like Honda batteries. They each have their quirks.
    Like you, I am a Honda IMA owner, as well as a Prius owner.
    I'll be watching your results with interest.
  4. S Keith
    799
    330
    AZ
    2003 Prius
    Hey Eric. You've probably seen enough of my blatherings back and forth with EQ1 on IC. I'll go through the motions on this pack. The bus bar inserts were cleaned up last night. I'll button everything back up and modify my grid charger to output 1.41V/cell (322V) to keep the charge peak voltage on the "gentle" side. I'm already working to line up Gen3 packs to source new modules.
    Thanks,
    Steve
  5. bwilson4web
    16,537
    I read one paper that claimed a discharged NiMH cell would 'dissolve' some the rare earths into the electrolyte and kills the cell. However, there is another hypothesis I have yet to test.
    The literature discusses something call 'activation' without details of what that means. One paper was a USAF sponsored research paper. Also, there was a Korean patent that claimed heating the cells to ~150 F made 'activation' easier. But I was never able to find a hard definition of NiMH 'activation.'
    Let me suggest putting the 'dead cells' aside and think about how you might 'Dr Frankenstien' try to resurrect.
    One last think, my hydration experiments suggests the active energy storage is a surface effect. What I found is repeated cycles seemed to 'spread the area' so the modules eventually achieved full capacity and leveled off.
    Prius Battery Photos
    S Keith likes this.
  6. usnavystgc
    3,159
    990
    Tucson, AZ
    How did you clean up the bus bars?
  7. S Keith
    799
    330
    AZ
    2003 Prius
    Bob, thank you for the link. That is very interesting. My goal is to identify any viable modules and set aside others for "tinkering".
    usnavy, I touched on the method of cleaning the bus bars in #22, sulfuric acid followed by the scraping off of what I believe is some sort of adhesive (the acid makes this about 50% easier) and gentle brushing with a brass-bristled brush. Here is a before/after shot:
    20150912_231552.jpg - Google Drive
    I finish with a soak in a baking soda paste.
    Steve
  8. usnavystgc
    3,159
    990
    Tucson, AZ
    Bob is the man.
  9. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    S Kieth,
    You have the right mindset for this. You'll enjoy learning the differences between the two types of modules.
    I always say, keep messing with this until it's not fun anymore.
    I have a pack open right now.
    Did a quick and dirty swap of a single module with no other testing back in February.
    Now a completely different module has given up the ghost.
    All were at 8.0v except this one that was in block 11.... it was at 2.0v,
    I had used one of my obdii recording devices on it the past few days. It was fun to put the results on a graph.
    Easy to se Block 11 was a mess!
  10. S Keith
    799
    330
    AZ
    2003 Prius
    Bob,
    The above is the only thing on which I have any input as the rest of what you discuss is well outside my experience.
    I don't know that the above is true with NiMH in general. Perhaps it applies to consumer NiMH cells or maybe even the prismatic type, but from my experience with the Honda IMA "D" cells, nothing like that happens. The Insight community is currently experience significant benefits from deep discharging both sticks and packs. It's an extremely effective tool in eliminating voltage depression and restoring balance. For whole-pack discharges, the polarity of the bulk of the cells in the pack is reversed. The worst of them can be run reversed for many hours, though under low current (less than 700mA for me). When discharge capacity is measured to 1V/cell following a deep discharge, capacity is typically 20-25% higher for a given load. This has also held true for individual sticks taken to 0.03V/cell avg, although the reality is that 5 are reversed and one is around .3V.
    I've been playing with the one module I mentioned above (#38). It's responding to aggressive cycling. My charger has a voltage regulated auto charge function that runs the max current up to a max voltage, then tapers current. It will eventually hold current and cut-off with deltaV. The module was accepting a 9A charge and subsequently discharged 2500mAh @20A to 6V. It discharged an additional 400mAh extracted during a constant 6V load taper between 20A and 1A. I read a summary paper this afternoon that suggests the panasonic prismatic cells can be discharged to 0.8V/cell. I took it to 4.8V @1A with taper to 50mA and pulled another 250mAh out of it.
    The next discharge to 6V yielded 2900mAh @ 20A and terminated at 3350mAh @1A.
    Eric,
    Thanks for the encouragement. I don't know that I regard any of this fun, but it's interesting and easy to obsess over :)
    Steve
  11. bwilson4web
    16,537
    Excellent!
    I'm using a 'Superbrain 989' and it doesn't have this capability. I have thought about getting a programmable power supply and load to run some 'Franken' charges. This is good.
    #31 bwilson4web, Sep 14, 2015
  12. S Keith
    799
    330
    AZ
    2003 Prius
    would have sworn you had a 989 from the pics... :) I have one too. It's great for hands-free cycling, but the Turnigy Reaktor 300W unit has greater capability and it logs data for export to logview (I currently have that disabled because the log is full from another project). It's basically a clone of an iCharger 206B. They're only $65 from Hobbyking, but they need a 12V PSU.
    I really like the decreasing discharge feature. It allows one to set a finish discharge based on initial in terms of percentage. I like to leave it at 5% so a 20A terminates at 1A and a 1A terminates at 50mA. My Avatar is actually a couple of them connected to HCH2 stick pairs discharging into a previously discharged stick pair. I can completely discharge all of the modules in an HCH2 pack @20A in under two hours. Very handy.
    I've brainwashed a couple of the Honda IMA folks into these units. They lack the ~80W discharge capability of the 989 with only 20W of internal dissipation capability, which makes hand-free cycling a little slower, but they make up for it in their 300W regenerative discharge capability... plus... it's like reusing the juice! :) One could start with depleted module and a full 12V auto battery of sufficient capacity and do hands-free cycling. I typically just discharge into a pair of series connected HCH2 sticks, 14.4V and 6500mAh capacity.
  13. S Keith
    799
    330
    AZ
    2003 Prius
    Let it rest for about half an hour. Here's a sample chart for a tapering discharge (20A discharge to 6V, hold 6V and taper current to 1A):
    I really don't like the voltage profile... prefer a flatter slope.
  14. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Some of the modules are never worth messing with, but they show up pretty early.
    Like my one with one 2.0v
    Clearly not recoverable.
  15. S Keith
    799
    330
    AZ
    2003 Prius
    Pretty sure this whole pack qualifies. The two highest voltage modules will only put out 2-3.5Ah. I'm running cycles on the next two highest (#35 & #37).
    Cycle parameters as follows:
    • 20A "Auto" charge to delta V. Typically limits peak charge to 9A and tapers significantly before deltaV cutoff.
    • 5A discharge to 4.8V w/taper to 10% further limited to 20W, so initial discharge is about 2.8A and it ramps up to 4.2A at 4.8V, then it holds 4.8V and tapers to 500mA. Total reported capacity includes the taper portion as well.
    One charger is logging the cycles. I still need to download the other.
    The downside to these chargers is the 20W limitation on internally dissipated discharges. I'll strap together about 13Ah of HCH1 sticks in series at 14.4V, which should accommodate a few cycles at 20A regenerative discharges to see if these things wake up.
    One thing that struck me is how prone these are to swelling. While I have them secure in the pack, it's a little disturbing to see the one module swell and create gaps that are slightly more noticeable than those of its neighbors. The pack "creaking" periodically was also disturbing.
    Module Testing
    #35 S Keith, Sep 15, 2015
    usnavystgc likes this.
  16. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    They will swell quite a bit at the loads you are putting them under.
    Do not take them out of the pack and attempt this.
    I've seen some pretty good clamping setups explode, simply because they cannot deal with the expansion.
  17. S Keith
    799
    330
    AZ
    2003 Prius
    Thanks for the warning. Mike D experienced this and documented on his site back in the day. Cautions about this phenomena abound. When I read that keeping them in the pack works well, that appealed to my lazy. :)
  18. bwilson4web
    16,537
    There have been credible reports here of modules blowing off their tops. One just a month ago.
    The pressure relief valve is stronger than the terminal seals and the case. You might consider getting a pH test kit and seeing what happens around the terminal seals. You can't see the KOH but it is right strong base.
    For safety, you might lay a piece of plastic over the top when cycling the modules, especially charging. Better to splash the plastic than face, eyes, walls, e.t.c.
  19. S Keith
    799
    330
    AZ
    2003 Prius
    That explains why it looks like all the terminals leaked.
    20150912_183221.jpg - Google Drive
    I'll see if I have any test strips. I assume a leak is more likely at the positive terminal, though it looks like the leak is on the negatives?
    Thanks,
    Steve
  20. bwilson4web
    16,537
    Our current hypothesis is the pack gets warm from excessive charging cycles. It can actually 'heat pump' to higher temperatures. This weakens the terminal seals allowing gas and electrolyte to leak out. Over time, it dehydrates the cells leading to current concentrated in smaller areas of the plastic mesh separator. When it melts a spot, the cell is permanently bad as is the module.
    On the bench, you're probably not going all that hot but in the car driving over hilly terrain and/or where the pack can get sun-baked. . . .
