Correct tonneau cover?
Discussion in 'Gen 4 Prius Main Forum' started by Connor Smith, Jan 6, 2017.
  1. Connor Smith
    Connor Smith Junior Member
    San Ramon, CA
    Hi All,
    Looking for some assistance. Can anybody confirm that this is the correct tonneau cover for a 2016 Prius?
    georgenc likes this.
  2. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Yes, that's the same part number as mine.
    georgenc and bisco like this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I think it depends on where you live - TOYOTA had at least 2 types.
  4. Prodigyplace
    12,691
    11,835
    Central Virginia
    There are 2 types in the US, depending on Trim level. My base level Two came with a cover.
    alanclarkeau likes this.
  5. Connor Smith
    San Ramon, CA
    I am trying to find out if I have the correct tonneau for a 2016 Prius.
    For those of you that have the tonneau, can you confirm the following:
    1. See second pic for a pic of my finger showing how wide the gap is. Does the tonneau have this gap, when fully extended, between the side of the trunk and the screen? Seems odd.
    2. See 3rd and 5th picture. Is this how your tonneau slides into the notch to hold the screen at full extension? This also doesn't seem right.
    3. See 4th picture. When fully extended, is the last part of the tonneau (closest to the hatch) supposed to lay downward at an angle?
    I have a feeling this isn't the correct tonneau for a 2016 Prius but I need somebody who has one to confirm.
    Thank you.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Mine is the same as your pictures, 1" gap either side, hooks into the slots at the sides the same and the rear flap bends down when in place.
  7. Connor Smith
    San Ramon, CA
    Thanks for confirming.
    That is so weird. It seems like a poor implementation in my opinion.
    The screen should reach all the way to the edges of the trunk; the hooking mechanism should be more lock-and-key like; the rear flap should extend flat, instead of bending downward.
    Just my 2 cents. I can't exactly recall what the setup was like on my previous Gen 2's but I thought it was better than this. Maybe somebody can refresh my memory.
    What are everybody else's thoughts?
  8. Prodigyplace
    12,691
    11,835
    Central Virginia
    The Gen 4 Trim Two cover is a totally different flexible cover. What Trim level do you have?
    The Gen 4 cover varies depending on trim level.
  9. Connor Smith
    San Ramon, CA
    Yeah I am fully aware that the Gen 4 cover depends on trim level.
    I have the trim associated with the flexible all black cover (Trim 3); I purchased the pull out "hard" tonneau cover (pics above) separately.
    Are the trunk dimensions of the trim 2/3 different from the trim 4 such that trim 4 cars with the tonneau wouldn't have the gap shown in picture 2 above? Or is this really just how the tonneau was designed?
  10. Tideland Prius
    16,627
    Looks about right. The Gen 3 has gaps on either side but the idea is that you can't see inside because of the pillars (same as the Gen 2 but my memory of it was that it was closer to the sides than the Gen 3). It's the gap between the rear seat and the tonneau cover bar that is the largest and can actually reveal the contents of the cargo area (if someone has a flashlight and shines in).
    Also, the bending of the last bit of the tonneau cover isn't new. Some cars do that (like the Volvo C30).
  11. alanclarkeau
    7,045
    7,593
    It's as good as it gets - I imagine it has to have gaps for clearance otherwise it could be quite difficult to pull out.
    RCO and kithmo like this.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Slightly neater than a blanket (y)
    alanclarkeau and RCO like this.
  13. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    It cover bends downward to somewhat block the lower window on the hatch.
  14. Prodigyplace
    12,691
    11,835
    Central Virginia
    In a hatchback I had a few years ago, I used a piece of carpet to
    1. Hide the contents
    2. Stop the contents from reflecting in the rear window, hindering rear view mirror use.
  15. Mendel Leisk
    41,982
    Checked mine (3rd gen), the clearance down the sides is around 1.5", about the same.
    (The angle is a bit deceptive with the ruler: viewed straight-on it's about 1.5".)
    RCO likes this.
  16. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    Oh more details, please. I thought I had read you can't buy just the tonneau cover there were other parts involved. How much "better" is this cover vs the flexible fabric one I have? What do you see are the advantages and disadvantages of this one?
    For the life of me I cannot figure out how the bendy/flexy tent pole like thing I have is supposed to go back in the bag. When I initially took it out it sprang open so I don't know how it was folded originally and every way I've done it doesn't seem right. I typically remove it when I'm doing something like hauling cardboard for recycling, but I just lay it on the hood of the other car in the garage. if I ever needed to move it while out and about I'm not sure what I'd do with it.
    RCO and Mendel Leisk like this.
  17. Prodigyplace
    12,691
    11,835
    Central Virginia
    I think yours is the same as my Trim Two. There is a diagram (on the bag,i think) showing how to twist it to fold up. I have done it once, but it is usually just easier to put it somewhere else when removed.
    RCO likes this.
  18. Mendel Leisk
    41,982
    Sounds like the fold-up style is not that hot? Difficult to deal with, ends up being left off the car?
  19. MrMischief
    426
    443
    Denver CO
    Mine is almost always on. I only remove it when I'm carrying something larger than what I can fit beneath it which is rare. Objects in my life mostly seem to be either small enough to fit in the back under that shade or so big/dirty I'm using the truck so YMMV
    RCO and Prodigyplace like this.
  20. Prodigyplace
    12,691
    11,835
    Central Virginia
    It's OK when in use. It has a wire frame around the edge. They expect you to twist to fold it like some folding sunshades.
