Correct wheel cap size for LE 17 inch wheels? Alternatives?
Discussion in 'Gen 5 Prius Main Forum' started by Winston Smith, Dec 21, 2024.
  1. Templeton
    Templeton Active Member
    372
    132
    usa
    2024 Prius Prime
    SE
    Did you install yours with, or without, the included steel rings? Are those necessary, i.e., will the caps stay in without the steel rings?
  2. Winston Smith
    Winston Smith Active Member
    476
    344
    OH
    2024 Prius
    LE AWD-e
    Installed with.
    That ring is "C" shaped and acts as a spring in support of the tabs. It's a piece of cheaper polymer and I'll guess that the "C" spring is made of the softest chinesium wire available. With neither part likely over-engineered, I thought I should use both.
    Templeton likes this.
