Corroded AC wiring harness 2010 - anyone heard of this?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius-Alfa, Sep 15, 2014.
  1. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Anyone have a make and model yet?
  2. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    They said compressor is still on the vehicle, so might cost extra for it to be removed.
  3. Den49
    Den49 Member
    498
    272
    Maryland
    Thanks to Prius-Alpha alerting us about corrosion of the compressor control circuit wire connector, I was prompted to neutralize the corrosion that you see in the bottom picture of post #25 above, paint the base of the connector and apply Eck ("Electrolysis, Corrosion, Kontrol") dielectric coating to the connection. Below is a picture of the renewed connector.
    Below is a picture of the products I used.
    The Loctite Extend Rust Neutralizer was applied first, followed by RUST-OLEM paint (black and white mixed to make gray), and then the Eck product inside the connection. I found the Eck product online at:
    What Is Eck Corrosion Prevention Coating? - Eck by Eck®
    When I called the company to ask whether the Eck product would work for the AC compressor connector, they provided me with a free sample and the technical data for the product. It looks impressive and should work a lot better than ordinary dielectric grease.
  4. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Is there a before picture??
  5. Den49
    Den49 Member
    498
    272
    Maryland
    Yes. The bottom picture in Post #25 of this thread is the "before" picture.
  6. Prius-Alfa
    Prius-Alfa Junior Member
    22
    Seattle
    Thanks for the suggestions and those are good questions. I'll look into some of those.
    The repair is a done deal. Doing it myself was not an option for a number of reasons.
    Update: I brought the old compressor home with me. It turns out I was wrong about those two fasteners on the plate the receptacle is mounted on. They are in fact small bolts with funky heads. I was able to bear down on them with a pair of channel locks and break them free. Still doesn't help for a repair though because there isn't enough slack on whatever the plug is connected to on the inside to pull it up more than about a quarter inch. The black plastic of the plug extends through the plate further inside the housing and has an o-ring around it. It doesn't come out far enough to see wires. You would have to remove the larger plate on that side of the compressor to get access to the connection inside. The three bolts that hold that plate on are recessed so one of those fancy sockets is required to get them out.
  7. Mendel Leisk
    41,747
    All the wires went in from the outside, and all the living slack pulled back on the in side: waste not want not. :ROFLMAO:
  8. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    I bet the black connector is just that. A connector that can be disconnected like the outside. It is most likely just a place to transition from the outside world to the sealed inside world.
    Do you have the make and model of the compressor?
  9. Prius-Alfa
    22
    Seattle
    Denso HFC134a
  10. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    I
    I sent an information request to Denso on the unit.
  11. Former Member 68813
    3,524
    983
    US
    Low miles or not, it has to happen after almost 1000 years.
  12. Prius-Alfa
    22
    Seattle
    Thanks for giving me a good laugh. I needed that. :D
  13. Former Member 68813
    3,524
    983
    US
    On a more serious note, what parts does one need to remove to get access to the said connector?
  14. Prius-Alfa
    22
    Seattle
    There's a good description in post #60 above in this thread on page 3. It's easy to do. Just three bolts to remove to get the air intake out of the way.
    Former Member 68813 likes this.
  15. OzPrius
    OzPrius Junior Member
    43
    New South Wales Australia
    Checked mine yesterday and it is fine. Thanks for a very informative thread guys :)
  16. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    What kind of pizza did you have?
  17. qettyz
    qettyz Active Member
    181
    206
    Finland
    I saw this thread about year ago and this started haunting me...
    Today i squeezed myself next to that AC 12V connector and lubed it well with contact cleaner what was quite oily stuff. I hope it protects nicely untill next summer when i dive there again and do same thing again. Now i can sleep better ;)
    used this stuff:
  18. gliderman
    gliderman Active Member
    751
    225
    Great info! Thanks!
  19. GreenTerrorPrius
    GreenTerrorPrius Junior Member
    56
    Just adding this here as i will be checking this part as well
  20. ChapmanF
    18,400
    HFC134a is just the refrigerant it's designed to be filled with.
    The model might be an ES18. That's what's in my mind, but I'm not looking at one right now. They have different sizes; the 18 refers to the displacement (in cm³? I'm not positive).
    But I'm pretty sure you could get a basic ES18 in either belt-drive or electric flavors. It's probably best to go by the Toyota ten-digit part number.
