Corroded AC wiring harness 2010 - anyone heard of this?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius-Alfa, Sep 15, 2014.
  1. TisBitAScratch
    TisBitAScratch Junior Member
    Virginia
    In the process of removing my intake manifold I separated the top part of the connector. It's still plugged in, but the top part seems to be broken. I have tried to disconnect it, but can't seem to figure out how to release it. I have to be careful or I may pull the wires out of the upper portion of the connector.
    Is the release on the back side (side toward the front of the car)? If there is a tab release should it be pushed or pulled? Top or bottom?
    Thanks in advance.
  2. Mendel Leisk
    41,792
    This is the AC compressor 12 volt connector?
    The release is at the front. I found a pen knife blade inserted in the gap just above the base and pried gently outward releases it.
    TisBitAScratch likes this.
  3. TisBitAScratch
    Virginia
    Thanks. I'll give it a try after I unload some of this frustration I've built up trying to remove the EGR cooler.
  4. Mendel Leisk
    41,792
    Got the lower bracket nut off? Never put it back on, just leave it off.
