Corrosion/burn on Wire Frame No 2 Plug/Ecu
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by supremejd, Nov 2, 2022.
  1. supremejd
    supremejd New Member
    Alaska
    I noticed that there's some corrosion/burn on the HV battery ECU where the Wire Frame No 2 connects. All other parts of the ECU are pristine. Do I need to buy a new ECU, or is it possible to salvage this one?
  2. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    I'd certainly be trying to clean it with some CRC contact cleaner or something blast that sucker out and see what you got after you get a lot of that pins all look like they're there.
    supremejd likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,472
    5,440
    Pacific Northwest, USA
    We've been trying to track down replacement sockets so you can solder a new one to the board... This is such a common problem that anyone who has rebuilt packs for years has a whole box of ECUs that look just like this. Someday when we track down a replacement plug we'll have lots of spare ECUs.
    As for yours, it looks like you got some missing pins. One of my friends who lost a pin soldered a wire to what remained of the pin on the inside and bypassed it from the socket and crimped it direct to wire frame. Alternatively you can get a used one on Ebay for $70 to $100.
  4. Tombukt2
    13,875
    2,521
    Durham NC
    This is on battery pack correct?
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    Unless you have mad skills with miniature soldering repair, just buy a new wire frame #2 for about $65 and a replacement ecu from ebay for $100 and call it a day. You don't want to be messing with this 5 times a year. Was this battery sitting unused for a while? If so, you likely will need 3 or 4 modules also.
  6. Prius2006GuitarGuy
    Prius2006GuitarGuy Junior Member
    Sweden
    Hey! Did you buy a new ECU ? If yes, have a link for me? Thanks!
  7. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    These units fail so rarely that getting a unit from a car dismantler is a viable option. Try some near your location.
