Cost-effective LED light bulb
Discussion in 'Environmental Discussion' started by chogan2, Jun 5, 2012.
  1. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    Home Depot now has an LED light bulb that has roughly the same lifetime cost as CFL. It's here:
    A19 8.6-Watt (40W) Warm White (3000K) LED Light Bulb-ECS 19 WW 120 at The Home Depot
    It's $10 for a 40-watt-equivalent bulb. Comparing the lumens, watts, lifetime, and price to the 40W-equivalent CFLs at Home Depot, it's a little dimmer and a little less efficient (lumens/watt) than the CFL. It's also apparently quite directional compared to a CFL.
    That said, if you can ignore the fact that it's dimmer, it has a lower lifetime cost (using $0.12/KWH). If you adjust for the dimness, it costs about 9% more (per lifetime lumen-hour) than the 40-w-e CFLs on the same site. I'd call that more-or-less break even.
    Interestingly, this is the first product I've seen on the Home Depot website that says "limit 10 per order". So it must be a pretty good deal, or something.
    To put it in perspective, last LED I bought was 15W, for $10. This is now 40W, for $10.
    Both this LED and comparison CFL are substantially less efficient than (e.g.) linear fluorescent tubes. But if you need a bulb in this package, it seems like you've now got an LED bulb that, at rated lifetime, is as cheap as CFL (at $0.12/KWH).
    As an afterthought: The rated lifetimes are getting so extreme that it may not be realistic to calculate the average cost based on the lifetime.
    These are rated at 50,000 hours. At 8 hours per day, that's more than 17 years. At 2 hours per day, that's ~68 years. I'd say the market for used lightbulbs is non-existent, and likely to remain that way. So it's a fair guess that much of the rated life of these bulbs will go unused.
    Unless you're planning to pass them down to your children, you'll need to substitute the lesser of the bulb's rated lifetime, or your own rated lifetime, in your own cost-effectiveness calculation.
    Pri4Us likes this.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Two out of the three LED lights I am using have no on/off switch, they are always on. (The other one is in a REALLY inconvenient location and I never want to go back up there)
    I have moved into buildings with all the light bulbs removed, so someone uses 'used' bulbs.
  3. bwilson4web
    16,528
    I bought ten, 10W, 1000 lm, LEDs on eBay for just under $90. Now I see them listed for just under $5 each. Then I bought a current limiting switching controller, $22, for a home-built, landing light. I'm using a Freshnel lense to focus the beam.
    I have to admit considerable disappointment with CFL lights. Some have been great but others fail too quickly. EDN did a report and believe it has to do with weak caps in the CFL power electronics that fail with too much heat.
    There is a high probability I'll be 'rolling my own' LED lights and controllers. URL? We don't need no stinkin' URL but we do need efficient, low-heat, high lighting and we're just not getting 'off the shelf' CFLs that meet our needs. The warehouse, hardware stores still don't get it.
    dave77 likes this.
