Cost for Spark Plug Replacement
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by AshleyF, Jul 1, 2022.
  1. AshleyF
    AshleyF New Member
    Good morning Fellow Prius Friends!
    I bought my 2012 Prius Plug In in April 2020 with about 80k miles on it. The only upkeep I've done since then are oil changes, fluid checks, and tire air pressure. I am now at 116k miles. In reviewing the maintenance guide I am due for a coolant flush and almost due for replacement spark plugs. I figured I would get done both at once. I am being told I need Denzo irridium part #3443 spark plugs. I am being quoted $550 for spark plug replacement and induction (?), and then another $200 for the coolant flush. When I look online, it seems that spark plug replacement should be about half that amount at maximum. Am I being ripped off for the spark plug replacement cost?
    N.J.PRIUS and bisco like this.
    52,823
    welcome! most definitely. anyone can replace the plugs, and 4 cost around 20 bucks. check with other dealers and local mechs if possible.
    be careful of the 'induction', might be a wallet flush.
    anddon't panic on the 120k service, it's not a hard and fast number. take your time and shop around, the plugs and coolant last a lot longer than that if you run late.
    N.J.PRIUS, pghyndman and AshleyF like this.
  3. AshleyF
    AshleyF New Member
    Thank you Bisco! As a woman, I can’t tell you how many times I’ve been ripped off regarding car stuff. I’ve gotten better as I’ve gotten older far as learning more about my car and doing some research. I got the quote from a place that was referred to me by a work friend, and the guy was super nice and seemed knowledgeable and patient. I’ve read conflicting stuff about the induction online for sure, I was iffy about it but he recommended after spark plug change. The reason that I started to look at all of this is because I’m now over 100k and I always thought that’s the big service time for cars, and my cars gas mileage has gone down in the last couple months. I mostly drive to and from work, same route, and my driving everything is the same but mileage gone down from 55/mpg to 49/mpg on my regular route. I’ve been reading a lot of about adding this seafoam stuff to the gas- thinking of doing that- wil research more before trying. I guess my major concern with the spark plugs is the car malfunctioning while I’m on the Highway. I love my old little Prius and would like her to keep running for a while.
    52,823
    the plugs won't give out on you on the highway, and loss of mpg's can have so many causes, you have to about trying to determine the problem a bit scientifically, starting with the low hanging fruit and moving towards the more difficult services, i.e.tires model and pressures, driving route and temperatures, air, cabin, hybrid battery filters and fans, oil level, brake drag, throttle body and maf, and etc.
    one area to consider is the egr circuit. it is a weak point in the gen3 engine, toyota won't acknowledge it, and most dealers don't understand it.
    i hate to throw you a curveball on top of everything else, but this is important, as ignoring it can lead to a blown head gasket or engine,
    there are many threads here, and a video @NutzAboutBolts . @Mendel Leisk also has advice in his signature.
    unfortunately, you either have to attempt it yourself, leave it to a dealer who will charge a fortune and probably mess it up, or try to find a mech willing to study the issue and perform the service correctly.
    N.J.PRIUS likes this.
  5. BiomedO1
    BiomedO1 Senior Member
    4,575
    2,401
    Left Coast
    Welcome Ashley; I've found that RepairPal.com to be an invaluable tool for people like you. So that you can get a reasonable estimate for the work done on your car at your local prices. You'll still need to watch-out for the shady shops; but at least you have a base price comparison for the work they are going to perform.
    Hope this helps
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Welcome, Ashley. Your location is a little vague, so it's hard to give advice about mechanics. But if you're close to Tampa, try calling Tampa Hybrids on Tuesday. (We're closed Monday for the 4th.) That way you don't need to be concerned about someone pushing bogus stuff like the induction flush. A half can of Techron in your gas tank will probably suffice.
    I'm not sure of our price for plugs, but it must be way under $500 since we charge $600 for an EGR system cleaning and that's a ton more work. Coolant changes are pretty simple. Todd can tell you what's really needed and what it costs.
  7. Mendel Leisk
    42,324
    Here's @NutzAboutBolts video on 3rd gen (applies to plug-in Prius as well) spark plug replacement. There IS an absurd amount of disassembly involved to access the plugs, but even so, what you're being quoted is robbery.
    The "induction..." bit should be waived; it's something you should research, not to be blindly agreeing to. Periodic removal of the intake manifold, cleaning of it, and the intake ports, and the throttle body is worthwhile. But leave for another day? DIY? See first link in my signature for more info. Also, here's another @NutzAboutBolts video, regarding the intake manifold cleaning:
    ^ I really doubt the dealership's "induction" service would doing this. More likely hooking up a bottle of solvent, running the engine near-stall for a while and blowing out impressive clouds of smoke from the exhaust. But not really cleaning.
    And link to thread referencing all his Prius videos:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    BTW, with your miles, now would be a good time to look into Exhaust Gas Recirculation cleaning. Neglected, it leads to head gasket failure. First link in my signature again.
    #7 Mendel Leisk, Jul 3, 2022
    N.J.PRIUS and jerrymildred like this.
  8. jerrymildred
    11,517
    14,167
    Tampa, FL
    Actually, once you've done it a few times, removing the cowl only takes a few minutes. But it's still ridiculous that it should have to be done.
    N.J.PRIUS and Mendel Leisk like this.
  9. AshleyF
    AshleyF New Member
    Thank you all for your help! I really appreciate a community like this to help someone like me! I got my car serviced today- spark plug replacement and coolant replacement (both inventer and engine) - skipped the induction - came to $450, which was lower than I was being originally quoted and they threw in the inverter coolant replacement which I forgot to ask about. They seem like an honest shop and nice people. I am happy with the service and price.
    N.J.PRIUS, bisco and Mendel Leisk like this.
