Cost/hours to remove/replace/clean EGR cleaner/etc
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TheLandYacht, Dec 6, 2020.
  1. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Hv battery average life span is much more than 10 years. 10 years is when the risk of failure begins but the majority last longer than that. I would recommend to the OP to get an OBDII bluetooth adapter and run the Dr. Prius app to get a rough estimate of battery health.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Even more work and expenses for the OP now :eek::eek::eek:
  3. royrose
    1,389
    953
    Foot of Pikes Peak
    OMG, $50 or less, then can repeat tests easily as desired. Grit, you better dump your 2012 Prius now before you have to do any extra maintenance. ;);););););)
  4. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    Still...not sure I'd spring the $1k-2k price-tag for the head-gasket on a "maybe" fix.
    As to the EGR/etc...yep, that's the plan. The leak-down test, so prevailing wisdom (on here) seems to say, is the definitive "is it the head-gasket" answer...and if it's not, then we proceed right to the rest...and with going for the EGR, everything else will be apart to the point where the intake/etc can be cleaned at the same time.
  5. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    Already have and OBDII reader, just not a USB one that'll let me run Dr Prius (or a laptop to do so).
    I keep my TorquePro up&running while on-the-roll tho. Anything you're talking about watching, specifically?
  6. royrose
    1,389
    953
    Foot of Pikes Peak
    Dr. Prius has 2 tests, one that shows whether the hybrid battery is functioning correctly (which I think you can figure out from Torque Pro) and one that does an estimate of battery life expectancy by fully charging the battery and measuring how long it takes to drain it under load. For example, my 2010 Prius with 100,000 miles shows about 70% reserve which is "good".
    To run Dr. Prius you need a bluetooth enabled adapter with an Android phone or a wifi one with an Iphone. I'm thinking you have one of those since you are running Torque Pro. What data are you getting from Torque Pro? I haven't tried that app.
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,013
    6,902
    Texas Hill Country
    No doubt you have a clogged egr. Head gasket leaks often start small and only occasionally cause the startup rattle. That is an early indication when a head gasket might save it. They can go nuclear fast and possibly throw a rod through the block.
    In reality, a proper leak down test and interpretation can id a head gasket leak, bad valves etc. Bubbles during the test in the coolant reservoir is a direct indication. The leak down test takes some disassembly and maybe two or three hours. Just taking out the spark plugs can be a chore on these cars.
    Losing coolant in normal operation is a sure sign assuming no obvious coolant leaks exist. A combustion gas test kit for the radiator is also a fairly good indictor for a head gasket and is easy.
    TheLandYacht and Ed Beaty like this.
  8. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    Not sure what others use it for. As for me, I use it to look at/for codes (and clear them)...as well as an aux dashboard (pretty much every time I get behind the wheel).
    That is one thing I have disliked about the Prius since I got it, not enough info on the dash on temps & pressures/etc.
    130282232_228834615329080_6612269218314780076_n.jpg 129882243_230205611899191_1155863674135235923_n.jpg
    royrose likes this.
  9. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
  10. rjparker
    11,013
    6,902
    Texas Hill Country
    The ideal 2ZR-FXE candidate would be from an obviously wrecked 2015 Prius or a 2015-17 Prius v since these gen3s have updated pistons and rings.
    The seller's ad can't be trusted when they claim it fits all Prii from 2010-17 (2016-17 std hatchbacks are gen4 engines) while the Prius c had a 1.5L. Apparently they don't id the year with the JDM imported engines.
    The US and JDM suppliers are also suspect when it comes to actual mileage. I have heard of "low mileage" US engines which Carfax proved were double the miles and older than advertised.
    I believe a relatively inexpensive specialist rebuild of the used engine is smart for ultimate reliability. New rings, seals, head gasket, timing belt and machined valves cost effectively since it is out already. Or just fix the head gasket if low repair cost is paramount and you don't expect to own it for another 150k miles.
  11. ASRDogman
    ASRDogman Senior Member
    8,047
    4,078
    $1000 is a good price! "IF" the mileage is what they say it is.
    The block may be the same for the Gen4 engines, but the head is different.
    But you could use the head off the original engine. Just have it check to make sure it's
    not warped or cracked. And replace the valve guide seals to get rid of most of the oil burning.
    Their place in Orlando is only 2 hours away from me. I'll make a note! ;)
    Oh, and that engine has a timing CHAIN, not a timing BELT.
    #31 ASRDogman, Dec 8, 2020
  12. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    Specialist rebuild...where would I source one of those? & What would the turn-around look like on something like that? This is my daily-driver for commuting to work.
    As to the head-gasket...my concern there is less about cost than...doing it and finding out I just wasted the money because of the low (suggested, on here) success rate of Head Gasket replacement.
    At which point I'd STILL have to do the engine anyway & will have wasted time & money on the gasket.
    EDIT:
    As to how long I own it, who knows? As many miles as I can safely & efficiently (ownership cost factors in, with repairs/etc, when does it start costing less to dump the old & drive something new?).
    Best case scenario, I'll drive this thing for a decade. But...I'm a realist, I expect Murphy to sneak up & kick me in the butt.
  13. ASRDogman
    8,047
    4,078
    Where did you see that on here? I have not.
    Could you show the pages for that conclusion?
    "IF" the head gasket is done correctly, with good parts, and you keep the EGR circuit cleaned,
    it should last a few thousand miles, at least..
  14. Mendel Leisk
    42,274
    Toyota offers a gasket kit, has head gasket and pretty much everything else as well, including the valve stem seals.
    ASRDogman likes this.
  15. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    I know I've seen that mentioned at least once or twice, browsing the forums...but now i can't find any of the mentions.
    Maybe that was an individual opinion rather than a widespread one.
  16. rjparker
    11,013
    6,902
    Texas Hill Country
    Austin would have auto machine shops that specialize in rebuilding heads. Maybe 3-4 days.
  17. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    Oh, I mistook "Specialist", thought you meant "specialist in prius"
  18. ASRDogman
    8,047
    4,078
    Hard to find something that's not there.
    Maybe several people do replace it. But "once or twice" doesn't make it first.
    It seems to me, tires are the first thing. And it's more important that an antenna.
  19. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    EGR Cooler was 100% clogged. Got a half-golfball sized chunk out of one of the "elbows" that connects the cooler to the EGR valve itself. Sorry no pics, wasn't gonna expose my phone to that mess.
    a full can of oven cleaner, most of a can of carb cleaner (he didn't wanna expose the electrical connection on the valve to high pressure water)...and 3 runs through the car-wash high-pressure wand is what it took to blast the cooler to the point it was flowing freely.
    He decided to tackle the EGR first rather than starting with the leak-down test
    rampante550, pjksr02 and Mendel Leisk like this.
  20. Mendel Leisk
    42,274
    Good you got on it. (y)
    Is he cleaning the intake manifold too, in particular the small diameter EGR passages, one per port.
    More info in post #6 link.
    pjksr02 likes this.
