Cost, installation, effectiveness: sound deadening material?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bookish Guy, Aug 23, 2018.
  1. Bookish Guy
    Bookish Guy New Member
    22
    How sensible is it to put into the Prius sound deadening material for a quieter ride? What's it cost, where does it go, how to you do it (door? floor?)??? Only two of us, so only concerned about front seat area.
    51,155
    there are quite a few detailed threads here. the materials are only a few hundred dollars. start with the floor pan under the spare tire, then the doors, the the floor under the carpets. it's all labor.
    very effective from what i have read, then a set of michelin energy savers is icing on the cake!
  3. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Here's one for free, just turn on the audio system, it did add cost to the vehicle. It's like saying I need it to be cooler in the interior while driving so I'm adding insulation to the car to keep temp stable. How about turn on the AC/heater, after all, it was a cost to the vehicle.
  4. audiodave
    audiodave Active Member
    798
    269
    US
    There big tin cans. It was a must as far as I was concerned. The roof is the only place I don't any but like to add some.
