Cost of Electric vs Cost of Gas - where is the break even point
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by hackenfort, May 18, 2017.
  1. hollyrik
    hollyrik Junior Member
    Bellevue WA
    The recent rise in the cost of gas had me look at this sort of question again, but from a bit different angle, that is for figuring out when to buy kWh at charging stations when away from home. I'm in $.10/kWh Washington state for home charging, and use 4 mi/kWh on EV and 55 mi/gal on HV for calculations. Back (well, not that far back) when gas was less than $3/gal, I eschewed the stations that cost $.25/kWh or more. It works out that away from home charging at $.25/kWh (what lots of Chargepoint spots cost) works out to about the same as $3.40/gal. So where I used to pass these up, I now will use them vs. >$5/gal gas costs if I'm not going to get home without running out of my EV battery. I'm even willing to pay up to nearly $.40/kWh as gas passes the $5 mark.
  2. BiomedO1
    BiomedO1 Senior Member
    3,585
    1,856
    SacTown, Ca
    Your break-even point is $0.396 kWh. The assumptions are $5.50/gallon, 50 mpg, and 4.0 miles/kWh. The numbers and math are skewed in our favor, because EV mileage may vary greatly depending on driving conditions. Right now, I'm averaging mid to high 4 miles/kWh, but this last winter I was only getting mid to high 3 miles/kWh - and we have very mild winters here.
    So if your total electricity cost is less than 40 cents/kWh and you need to do something else while the car is charging - it's worth plugging-in otherwise just run it on gas......
    #62 BiomedO1, Jul 4, 2022
  3. hollyrik
    Bellevue WA
    For those interested in determining their own breakeven points using their own cost and mileage estimates, the math is straightforward:
    Find electricity rate given pump price: $/kWh = $/gal * m/kWh / mi/gal.
    Find pump cost given electricity rate: $/gal = $/kWh * mi/gal / mi/kWh
