Cost to Change Tires?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cdogstu99, Apr 13, 2017.
  1. cdogstu99
    cdogstu99 Junior Member
    37
    boston ma
    Hey guys I have a 2012 Prius that I just acquired. It came with Snow tires and a newer set of regular tires. Looking for a place to change out the tires and wondering what I should be paying for someone to do this? Do you recommend bringing to a Toyota dealer or will any regular tire place do? Thanks!
    iPhone ?
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Get a set of steel rims, fit winter tyres and swap rims twice a year according to season, that way the tyre sealing-beads are not compromised by repeated changing! (think about it!), plus the wheels only need to be balanced once when the tyres are first fitted!
  3. fuzzy1
    10,719
    Any regular tire shop should be fine.
    Price? Sorry, I don't know what is reasonable. My tire sets are on separate rims, and I swap them myself.
  4. WilDavis
    2,493
    2,155
    49
    I had my summmer wheels fitted yesterday, no charge, part of the deal when I purchased them this time last year (Town Fair Tires)
  5. bisco
    52,876
    my local gas station charges 30 bucks per tire to swap old tires for new. that included balancing and disposal.
  6. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    walmart 20 a tire
  7. bisco
    52,876
    oh my, i would never go to walmart. have you seen how people dress in there?(n)
    jerrymildred, Rebound and WilDavis like this.
  8. Mendel Leisk
    42,361
    If you go the rims route, these are good:
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    steel rim lug nuts, part no: 90942-01007 (plain, open-ended, galvanized)
    WilDavis likes this.
  9. fuzzy1
    10,719
    I did, when it was the only game still open* in town. For the tire shop, I didn't have to go inside and witness how customers dressed there. :)
    *Costco was open too, but wouldn't service tires not bought there. The car in question still had the factory tires.
    *Never mind Les Schwab's ad about staying open late. When we called from the road, just before closing, they wouldn't stay open until we could get there.
    #9 fuzzy1, Apr 13, 2017
  10. Currahee
    Currahee Member
    103
    34
    CT
    Local place I go to is just under $80 for four tires m&b. Tire Rack has a directory of installers with flat pricing: Delivery & Installation
  11. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    There is a local guy here that charges $5 a tire to remount, I have a tire changer that i use to re rim small tires and a bubble balancer
    So I guess it depends
  12. WilDavis
    2,493
    2,155
    49
    "bubble balancer"? I've never heard of one of those, does it dynamically balance the tyre mounted on the rim?
  13. Rmay635703
    2,704
    1,730
    2013 Chevy Volt
    Lol
    You put the tire on the rim, lock the bead then set it on the balancer, you add weights till the bubble on the balance centers.
    Hi tech
  14. WilDavis
    2,493
    2,155
    49
    In
    I just looked it up! How is it better than having the tyres dynamically balanced? It's STATIC fer gawd's sake! No matter, if that's what works for you go to it! How does it know whether the weight should be on the inside or the outside of the rim?
  15. Rmay635703
    2,704
    1,730
    2013 Chevy Volt
    FREE = Better
    I would never pay to mount anything below 14" and never pay to mount trailer tires.
    Most of my alloy rims have a different outer flange than inner and my weights won't clip on to the outside anyway, the places I go in a hurry to mount and balance always put the weight to the inside and given most tires offset in not out that's usually where they belong.
    Only time dynamic is needed is on big tires with bad rims or old crappy tires on good rims.
    #15 Rmay635703, Apr 14, 2017
  16. WilDavis
    2,493
    2,155
    49
    I gather then, that you have never been faced with changing a tyre on a Mini (no, not the bloated BMW version, I'm referring to the original BMC version which was built from 1959 to 2000!!) The original Mini had 10" wheels, and the tyres were impossible to remove, until you realised that the rims were asymmetrical and the tyres could only be fitted or removed from the inside edge of the rim. I can't tell you how many times I've witnessed a gorilla-sized moron ruin a brand new tyre by trying to stretch it over the outside of the rim! I'd be willing to pay a tyre shop to let me use/borrow a machine. Same goes for dynamic balancing too!
  17. Rmay635703
    2,704
    1,730
    2013 Chevy Volt
    My Subaru 360 had 10" tires with inner tubes and split rims, take off the bolts and fit a new tube and tire replace and tighten the bolts in a star pattern.
    Easy peasy no effort required.
  18. WilDavis
    2,493
    2,155
    49
    Of course it would be, having an inner-tube, but the wheels to which I was referring were fitted with tubeless tyres! ;)
  19. Mendel Leisk
    42,361
  20. Rmay635703
    2,704
    1,730
    2013 Chevy Volt
    Damn straight, I've had 3 full size adults in my 360 on the freeway, always fun
