cost to replace front struts?
Discussion in 'Generation 1 Prius Discussion' started by ashleyclark, Jan 3, 2014.
  1. ashleyclark
    ashleyclark Junior Member
    a potential buyer for my 2002 classic is asking how much he'd have to shell out to replace the front struts only. I found a gen II thread saying $1000 is on the high side for replacing struts all around. rough estimate anyone?
    thanks!
    Ashley
  2. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    I found KYB cloeouts online for $53.XX each for front struts with free shipping reduced from $70.00. I can get the website when I get home and send a link. It is not a hard job so find an independent shop that would do the labor for you per hour. A Toyota dealership cost should not even be that high. I will be doing this job myself soon to all four and will only be spending $180 with new front dust boots barring I do not need or brake anything while doing the job.
    TomK
    trentofdestiny likes this.
  3. Patrick Wong
    18,210
    6,512
    You haven't listed your geographic location. Big difference between labor costs on the East/West coasts vs. a less-populated area.
    If you want an accurate estimate, try calling a local Toyota dealer. My guess is that the quote will be $1K or more. Then, try calling an independent servicer in your area and see what is quoted to you.
  4. vaughnstark777
    190
    33
    Roy, WA
    2001 Prius
    I
    Ebay has all 4 corners for $175 and each of the front corners starting @ $62
    SCH-I605 ?
  5. ashleyclark
    Thanks! BTW I'm in Richmond VA. I'll pass on the info.
