Costco Gas
Discussion in 'Gen 3 Prius Main Forum' started by Ted in Olympia, Jan 30, 2011.
  1. ghostwhowalks
    ghostwhowalks Junior Member
    Dallas, TX
    I have filled gas at Costco, and BJ's for years, even before getting the new Prius.
    BJ's gas gives me improved mileage. Better then big brand names.
    Costco probably has multiple distributors. The one costco close to home(1 mile away) always end up giving me bad mileage(calculated mileage 48-49).
    There is one on way to work(about 10miles away). Gives me better mileage(calculated mileage 52-53)
  2. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    ...if you live in a Refomulated gasoline area, you are stuck with a lower energy content (lower MPG), which EPA believes is a cleaner E10 blend for metro areas with smog/ozone issues. If you are outside of RFG area (inner Dallas may be RFG but nearby regions may not be) then you could see higher MPG non-RFG fuels but no guarantee...it can vary. But if you see a pattern develop that may indicate some stations may have a certain supply situation more or less favorable for Prii MPG. Previously I have posted a map so you can see where RFG is used also on EPA website they give county by county breakdown where it is used.
    ghostwhowalks likes this.
  3. curteye
    curteye New Member
    Maui Hawaii
    Aloha guys, just to chime in.
    No diff in mileage here on Maui.
    Costco gas here can be aprrox .90 cent a gallon cheaper than the big boys.
    As of this past week (Nov 10-16 2014) gas is typically $4.40 a gallon here.
    While at Costco it was $3.45 yesterday the 17th.
    But as posted, no real mileage diff.
  4. alexcue
    alexcue Active Member
    346
    311
    So Cal
    I'll just have to chime in on this one. Some of my best fuel economy results have been with Costco gas. However, my driving is very mixed and it depends on how much elevation change i have during a tank of gas.
    Costco and Mobil are my favorites, and are very consistent. Arco, which seems to be the cheapest gas (price wise), usually results in my worst observed fuel economy.
  5. theotherone
    theotherone Junior Member
    67
    24
    Greenville, SC.
    I find no difference in MPG when using Costco gasoline. I would check tire pressure, especially if there are a lot of temperature & pressure changes.
    By the way, Costco (along with BP/Arco) is a Top Tier gasoline.
  6. GregP507
    GregP507 Senior Member
    3,002
    481
    I've noticed the same thing, but I'd bet you'd have a devil of a time proving it in court.
  7. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    I notice that GasBuddy.com seems to have started noting "TopTier" brands when they give you the list of stations in your area.
    ...well California is reformulated gasoline, so one woud think not too much difference there.
    Hawaii sounds good about now!...supposed to 15F tonite. Does HI have E10?
  8. lester williams
    227
    68
    mississippi
    I realize this thread is about Cosco gas, but there is not any noticeable difference in ''Sam's Club'' or Shell gas in my car--- except price. I usually run the Shell @$2.59 right now---- $2.45 at Sam's. Filled there Sunday...
  9. GregP507
    3,002
    481
    "Top Tier" is a trademark designed to designate gasoline with particular detergent additives specified by certain automakers to use in their engines. It may imply such, but doesn't denote a higher quality of gasoline than any other gasoline.
  10. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    All gasoline comes from the same pipeline, so there is no difference in gasolines other than additives.
  11. GregP507
    3,002
    481
    I'm still a bit skeptical. Although all gasolines have to meet the same government standards, I haven't seen anything to suggest that the energy content of all gasolines is exactly equal. I used to routinely measure my exact mileage from each tank of gasoline (before I got the Prius which shows it in real-time), and I saw a difference in fuel economy between fuel vendors. I'm not talking about E10 vs E15, which has a obvious difference in energy content, but grade-for-grade, some brands produced lower fuel economy numbers.
    I'm not a petroleum engineer, but I believe that gasoline is not a pure substance, but a mixture of many different hydrocarbons, which when blended, conform to a certain standard. Depending on the source, it may be reasonable to assume that there would be differences in energy content, and therefore fuel economy. I may be out to lunch, but I remain uncertain until I see hard data.
  12. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    ....take a look at this USA map of many different gasoline requirements in the US.
    http://www.api.org/~/media/Files/Policy/Fuels-and-Renewables/US-Gasoline-Requirements-Map.pdf
    We also have winter/summer blends, E0 in some areas, Regular , Mid, Premium Octane.
    If you want to say, within some regions, all stations get the same basic gaso, that could be correct in some regions, especially if you are in a RFG region where EPA controls the recipe.
  13. KenSoren
    KenSoren Junior Member
    31
    Yucaipa, CA
    Just curious - do they still make you use E10 gas there?
    Doesn't seem you would have the air quality problems the ethanol blend is required for.
  14. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    We also use Costco gas.
  15. GregP507
    3,002
    481
    I can confirm that this has also been my experience. My mileage was always measurably less after filling up at Costco, (and similar discount-gas outlets) so I stopped filling up there because the cost-saving didn't match up to the fuel economy.
    #75 GregP507, Dec 4, 2014
  16. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    I detect no discernible MPG difference using Costco fuel.
  17. GregP507
    3,002
    481
    #77 GregP507, Dec 4, 2014
  18. stephensprius
    670
    226
    wow, that's a huge difference. Never that big here.
  19. stephensprius
    670
    226
    I haven't filled up at a holiday or SA for a while, been doing costco. Maybe next tank i will try it and see how it goes.
  20. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    ...if you're outside of a USA reformulated gasoline area, there could possibly be minor variations in MPG because the energy content is not a controlled spec (octane is the controlled spec). If you are inside of a USA reformulated gasoline zone, not much variation as the EPA recipe essentially sets the energy content (lower energy content to allow for lowest emissions).
