Could I Sue Toyota Dealer for this? Possible Negligence in Free Recall Service
Discussion in 'Gen 3 Prius Main Forum' started by Roadie_, Jul 26, 2024.
  1. Roadie_
    Roadie_ Junior Member
    30
    KY
    A few weeks ago I was traveling out of state and the car (2013 - 98k miles) went into Fail Safe mode (see post history for details). Pulled over, scanned codes and had no choice to tow it to dealer as they were close by.
    I typically avoid dealerships like the plague for the following reasons, but I was traveling and far from my home and tools so not much choice.
    Did some research and received codes P0A94, P0A7A & P324E. Inverter failure. After researching, I stumbled upon this statement from Toyota, deeming this recall free of charge to repair.
    After $190 diagnosis fee of them verifying what I already knew, they informed me they are unable to perform service for free as my car has a Rebuilt title. Then quoting me nearly $4,000 for repair. I showed them the NHTSA document above and they still claimed I wasn't honored due to rebuilt title status.
    I refused service and decided to purchase a salvage inverter to do the job myself. Since I was traveling (and without my tools) they told me they could replace the used inverter for the price of labor only ($550), which I agreed to.
    The repair has been done a few days ago and all is well, but I'm now reading they should've performed the service free of charge regardless of title status. NHTSA states "Just because the vehicle was salvaged doesn't absolve the manufacturer of its obligation to repair a defective vehicle subject to recall, so long as it's still drivable"
    I guess my questions are:
    • 1 - Is this actually true? Should they have provided the service for free regardless of title status?
    • 2 - If so, could I possible seek legal action against them? Or did I screw myself for declining the initial service of them disassembling mine and fixing it? Is it too late?
    At the end of the day, I paid about $600 for the used inverter, and $1,200 for labor & following services - Engine & inverter coolant and CVT drain/refill. I was planning on doing all these myself within the next month but I'm limited on time.
    Thanks for any insight!
    #1 Roadie_, Jul 26, 2024
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    This is not the correct website to be seeking legal advice.
    Brian1954 likes this.
  3. Roadie_
    30
    KY
    I understand, but i'm not necessarily seeking specific legal advice. But rather asking if they should've done the performance or not based on my situation. I figured individuals in a Prius forum would have more insight on the specific recall more than a legal representative would have.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,497
    2,482
    Taylors, SC
    Not legal advise, but financial advice.
    Unless you are legally skilled or an attorney, yourself, suing Toyota will cost you at least three times what you paid to have your car repaired.
    As Dirty Harry asked, "Do you feel lucky?
    Check your warranty. It should state that a salvaged title absorbs Toyota of any warranty.
  5. Roadie_
    30
    KY
    Absolutely - Suing was definitely the wrong terminology used by me. I know It wouldn't be feasible or realistic. I should've purely stated "Hey, Did I screw myself over a free fix?" instead.
    Regarding warranty, as far as I know I don't have any. It's 11 year old car I purchased privately. Anything similar would most likely be manufacture-issued, such as recalls. But this isn't my realm.
  6. Georgina Rudkus
    3,497
    2,482
    Taylors, SC
    A lot of insurance companies will not write policies for "salvaged title" vehicles.
    States also have such regulations.
    Even the UK MOT will not certify such a vehicle for road use.
  7. Roadie_
    30
    KY
    #7 Roadie_, Jul 26, 2024
  8. JC91006
    16,815
    8,596
    I would submit a claim in writing to Toyota corporate for reimbursement. The servicing dealer has little say on this issue. If this was a "recall", the branding of the title really shouldn't affect you getting it serviced. If it's a "warranty" item, then a rebuilt title car would not get any type of free warranty work.
  9. Georgina Rudkus
    3,497
    2,482
    Taylors, SC
    Many warranties are voided when the OEM components are modified.
    Many shops a/d/or dealers will refuse to work on such vehicles, since just trying to figure out what was modified and the mistakes that may have been made may result in an extraordinary amount of troubleshooting hours.
    That's why, with modern cars, I would only recommend only reversible cosmetic mods.
  10. Georgina Rudkus
    3,497
    2,482
    Taylors, SC
    You can and might get some credit without regard to a very slim chance.
    If you don't submit a claim, the answer is a 100% No!
  11. JC91006
    16,815
    8,596
    I believe with a recall, they have to assume the equipment that's being recalled is original if there is no proof the recall item has been replaced.
    But in this case, I believe it's not a safety recall, it's more of an extended warranty on the inverter. So he may get denied on his claim to Corporate. But I would still try, the worst answer is NO and that's exactly where you're at now.
  12. Roadie_
    30
    KY
    Makes sense. That’s exactly what I figured and I’m hoping it’s the case so I don’t feel as bad about spending the money. It’s just that other many others have said the opposite and that I should have been covered, so I wanted to pool an alternative perspective of thoughts.
  13. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    The link is for "Safety Recall 20TA10" which is for a software update in the inverter. It is not for repair or replacement of the inverter.
  14. ChapmanF
    18,454
    The Toyota communications that do apply to the OP's situation are:
    23TE02 23TE03
    Between them, they both cover any Prius built from late January 2009 (model year 2010) through late November 2015 (model year 2015), and any Prius v built from late August 2011 (model year 2012) through late November 2017 (model year 2017).
    There is no mileage limitation and the coverage extends to 20 years from the date of first use.
    If the trouble codes include P0A94, P0A1A, P324E, or P3004, the coverage falls under 23TE03; if they include P0A7A or P0A78, or the cause was a "thermal event", or the cause is unclear and can't be shown not to have been a "thermal event", the coverage falls under 23TE02. The unlimited mileage and 20-year window are the same for both coverages, and the repairs are the same, so the two different coverages only help keep statistics on which kind of thing went wrong.
    In this case, the OP has P0A94 and P324E, triggering coverage under 23TE03, and also P0A7A, triggering coverage under 23TE02, Either coverage on its own would be enough to cover the repair.
    Both coverages were also clarified, as of June 2023, to confirm that they do apply to cars that have had salvage, total loss, true mileage unknown, or other similar titles. (That's better than some of the normal warranty coverages, which don't apply then.) The clarification was highlighted in red in the update, like this:
    "A few weeks ago" sounds like after June 2023, so it seems to me the dealership ought to have understood the coverage applied.
      File size:
      2.1 KB
    Mr. F, Mendel Leisk, mjoo and 3 others like this.
  15. Roadie_
    30
    KY
  16. Roadie_
    30
    KY
    Yep, literally was two weeks ago to the day that It happened, they fixed it earlier this week as I was out of town & they were booked full.
  17. JC91006
    16,815
    8,596
    so maybe take that document into the dealership and ask to speak with the service manager (not a lowly adviser) to straighten all this out
  18. ChapmanF
    18,454
    That link is still about an earlier recall that would have updated some of the car's firmware.
    For the customer service programs that should have covered your hardware repair, see the links in #14.
  19. mjoo
    mjoo Senior Member
    1,162
    1,331
    Michigan
  20. ChapmanF
    18,454
    Note the deadline on the http://www.toyotapriusinvertersettlement.com site. Both of the documents linked in #14 instruct the dealer who denied your coverage to give you a copy of the repair order with appeal instructions on it:
    Before coverage under this program is denied, Toyota dealers must contact [email protected] to confirm if coverage, loaner or towing should be denied. If it is confirmed that the vehicle should be denied coverage, the dealer must provide a copy of the repair order to the vehicle owner/lessee with the following verbiage:
    “To appeal the denial of a loaner, tow or repair related to the Inverter and/or IPM, you must submit an Appeal Form, which can be found at http://www.toyotapriusinvertersettlement.com. Your appeal must be submitted within 45 days from the date of this document.”
    If the dealer did what they were s'posed to do and gave you a copy of the repair order with that on it, then naturally, your appeal must be filed within 45 days of them giving you that.
    If they didn't give you that, your appeal must be filed within a year of them denying you coverage.
