Couple of Tech Questions (from a techie)
Discussion in 'Prime Main Forum (2017-2022)' started by ttait, Oct 25, 2016.
  1. ttait
    ttait Active Member
    273
    163
    Southern California
    Does any one know if it's possible to change the 'guts' of the Qi charger to enable 'Fast Charge'? If I use phone nav. (Waze) the regular charger barely keeps up.
    Also, Is it possible to modify the Siri eyes free to call the Android Assistant instead?
  2. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Check out the max wireless charge input capacity for your phone. Usually wireless has far less power than wired and I wrote it off as a solution for powering phone nav. Just not enough power for that.
  3. ttait
    ttait Active Member
    273
    163
    Southern California
    Actually, I have a separate fast wireless car charger that I have used. It keeps up with Nav just fine. I would rather not have to use the 12 volt plug and wireless charger if the car already has one built in. The phones input charging capacity is not the issue.
