CR says 60 MPH = 3495 RPM
Discussion in 'Gen 2 Prius Technical Discussion' started by toronado455, Dec 9, 2007.
  1. toronado455
    toronado455 Member
    179
    22
    Southern California
    CR.
  2. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    After riding motorcycles with a redline over 10,000 rpm, even 3,500 seems awfully slow.
  3. bwilson4web
    16,310
    There is good evidence that keeping your ICE rpm below 2,600 rpm improves overall mileage.
  4. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Agreed. However, I was responding to a comment of:
    Had the comment been, "Do any hybrids have tachs. I think it would be hard to optimize your mileage without a tach." I would have agreed with the comment in the first place.
    There is nothing hard about having a car without a tach. And if you are planning on trying to optimize your mileage, then there is aftermarket equipment you can purchase for the Prius to assist you.
    So if you insist on having a tach, you can get one for the Prius.
  5. toronado455
    toronado455 Member
    179
    22
    Southern California
    Consumer Reports has tested several CVT cars. In order to publish a "RPM@60MPH" spec, they must have a test that uses a perfectly flat road surface and I'm sure they must try to do the test in neutral wind conditions also.
    Here are the specs they publish for some other CVT cars:
    Toyota Camry Hybrid: RPM@60MPH=1700
    Honda Civic Hybrid: RPM@60MPH=1810
    Nissan Altima 4-cyl: RPM@60MPH=1940
    Nissan Altima V6: RPM@60MPH=1945
    Nissan Versa: RPM@60MPH=2050
    So clearly, several cars with no fixed gearing can be put through their test and come out with an accurate ICE number. Even if there is some fluctuation in the ICE RPM during the test, they must have some way of averaging it so that they can publish something relevant.
    Now look at the Prius number:
    Toyota Prius: RPM@60MPH=3495 Holy Cow!!!
    Clearly it must be the MG2 number, not the ICE number. And they need to include of explanation or else, better still, just give us the ICE number like they do on all the other CVT cars they test.
  6. Danny Hamilton
    926
    94
    I haven't read the CR article, but in this thread there is just too much missing information.
    What was the state of charge of the HV battery?
    What was the engine coolant temp?
    What stage of operation was the Prius in?
    Had it most recently accelerated or decelerated?
    I agree that it sounds like MG2, but with so much information unknown or assumed, the number is rather meaningless.
  7. Frank Hudon
    Frank Hudon Senior Member
    4,147
    lets remember here that the ICE doesn't directly power the vehicle to wit the fact that it will go into stealth and still accelerate. MG2 moves the car as it drives the chain that turns the gear reduction gear set. Plenty of pix here on PC to show that and the final drive reduction is stated as 4.113 to 1 so 3495 /4.113= wheel speed of 849.7 RPM times the circumfrence of the tire / feet = well you get the rest of the equation. The underlying fact is the ICE isn't directly connected to the wheels so ICE RPM isn't worth stating. CR looses again. Honda's IMA has the ICE directly connected to the wheels.
