Crack in trunk where repair kit is placed
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Talha Maqsood, Sep 4, 2018.
  1. Talha Maqsood
    Talha Maqsood Member
    46
    26
    Pakistan
    2015 Aqua
    A Crack is developed in trunk where Tyre repair KIT is placed. Not a crack actually, can call it dislodge. I don't know when, where and how this happened. I am really worried about its repair. pictures are attached.
    Can anyone suggest what kind of repair i should do on it. OR i just let it be as it is ??
    please suggest IMG_20180904_121625.jpg IMG_20180904_121635.jpg IMG_20180904_121635.jpg
    49,506
    i wouldn't be overly concerned my dear, just find out what they use and recaulk it.
  3. Mendel Leisk
    38,735
    I'm not sure anything's wrong here, it doesn't appear to be opening up. Maybe a different story seeing the real thing?
    The appearance below deck in the hatch area on ours (2010 Prius hatchback) is pretty utilitarian too: seams are much more unfinished looking, and the sealant spread over is used liberally and kind of haphazard.
    49,506
    i don't have a spare tyre well to look at anymore.:unsure:
  5. Talha Maqsood
    46
    26
    Pakistan
    2015 Aqua
    Its opening up, that is why i am concerned, looks like very difficult to joint it as it was earlier i can only fill it with some sealant. My concern is it doesn't open up any more. :(
  6. bisco
    49,506
    was it ever in an accident?
  7. Talha Maqsood
    46
    26
    Pakistan
    2015 Aqua
    Nope never into accident, But yes it hit bumps on road few times mostly when loaded with four people + luggage
  8. Mendel Leisk
    38,735
    I'll defer to your first-hand judgement, but that pic sure looks fine. It's not helping your case, lol.
    Is there a comparable weld on the opposite side of the car?
  9. Talha Maqsood
    46
    26
    Pakistan
    2015 Aqua
    I think the extended portion had a hit on a bump (as here my car gets hit many time from below) and pulled a little back which created this crack. all other weld are fine
  10. Mendel Leisk
    38,735
    Ah, looking at the other picture, I see more clearly:
    Two failed spot-welds? I would have a body shop look at that. They need to clamp or hammer it back together and re-weld.
    #10 Mendel Leisk, Sep 6, 2018
    Talha Maqsood likes this.
  11. Talha Maqsood
    46
    26
    Pakistan
    2015 Aqua
    Yes i guess so, I had to visit a body shop eventually. (although i hate them they just don't care about your car)
    Mendel Leisk and bisco like this.
  12. bisco
    49,506
  13. Talha Maqsood
    46
    26
    Pakistan
    2015 Aqua
    Visited the body shop at last, they said they will push with hydraulic and perform spot weld then painting. it will take two days and it requires to remove rear bumper and any other thing in back, and it is also good to go with this, just fill it with silicon to stop dust ingress. so i preferred not to perform any work. Just filled it with silicon.
    bisco and Mendel Leisk like this.
  14. bisco
    49,506
    i'd have done the same.(y)
    ztanos and Talha Maqsood like this.
  15. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    I would recommend that you get it fixed.
    Only after removal of plastic shields you will be aware of the damage.
    Max 2~3 hour job.
    Are you in Lahore?
  16. Talha Maqsood
    46
    26
    Pakistan
    2015 Aqua
    No I am in Sadiqabad, Here in RYK Toyota Motor service is slow & pathetic
  17. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    Go to any other renowned body shop. You will be able to overlook the work.
