Cracked 11.6in touchscreen
Discussion in 'Prime Technical Discussion' started by Ceryx, Oct 29, 2019.
  1. Ceryx
    Ceryx New Member
    2020 Prius Prime
    I've got a 2020 Prius Prime with the larger 11.6in touchscreen. Today I cracked the touchscreen portion pretty badly and it no longer registers touches (though the display itself seems fine). The dealer quoted $6300 for parts alone to replace it, as they won't just replace the screen. The head unit doesn't look all that difficult to remove based on videos. Does anyone have experience with replacing the screen? I'd obviously prefer to just replace the capacitive touchscreen part, but even replacing the whole screen is surely less expensive.
    The screen crack was my fault (though it was a response in frustration to a malfunctioning touchscreen system that was constantly rebooting and was doing so while navigating in an unfamiliar area.) Insurance said they wouldn't cover it. The car's also a lease and needs to eventually be passable. And yes, I know, I need to be more careful. :(
    #1 Ceryx, Oct 29, 2019
    Denwah and bisco like this.
    52,854
    welcome!
    major bummer. might be worth the 20 bucks to look at the service manual at techinfo.toyota.com
    all the best!(y)
    followingalex likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Sorry to hear the misfortune. Yeah, replacing that touch screen is going to be very costly. I don't know how much you can save by DIY, since the parts is what is so expensive. I remember a thread with a video on how to remove the head unit from PRIME, but can't find it.
    I did find this video showing how to remove the dash panel and head unit along with the screen to access the controller, but I don't know if it helps. Good luck and keep us posted.
  4. Leadfoot J. McCoalroller
    8,288
    7,802
    Pennsylvania
    2018 Prius c
    You can almost certainly buy that screen and touch digitizer seperately, but not from Toyota. The challenge will be figuring out the part interchange. A part like that typically costs less than $150.
    I’ve seen many OEM automotive touchscreen replacements sold on Alibaba. They are only occasionally identified by fit application, usually described only by size and connection type. So it wouldn’t be an easy search, and might require some disassembly of your existing unit to gain clues.
    But if it saves you the better part of $6,150? Just food for thought...
  5. followingalex
    followingalex Junior Member
    42
    New York
    first things first, i recommend therapy and meds to get that rage under control.
    or a higher paying job so you can afford to fix the mess(es) you make..
    I've had mine over a couple years now, same screen, and it's taken a beating.. cracking the screen with a punch is certainly not a trivial task, you must have gone to town on it.. that's the concerning part.
    Diemaster, MTN and bisco like this.
  6. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    A used 11.6" head unit/screen should be available from an older salvage Prius. The electronics in the head unit my be different but the screen should be same and probably could be swapped with the 2020 Prius head unit. $6000 is a ridiculous price to pay for a replacement.
  7. ETC(SS)
    7,555
    $6,150?
    Yeah.
    Right...
    I think that even without an 11" screen, I would see a very large message indicating that it's time to replace your dealer.
    Meanwhile.....
    I would do exactly nothing for 6-12 months other than buy a phone mount or old school GPS for navigating and switch to decaf.
    I'd also start a replacement fund for the head unit and wait for more people to have more trouble with their infotainment systems so that there will be more demand for screen replacements.
    As a wiser person than myself has already pointed out, he digitizer screen is probably a $100-$200 part, and it's going to be a lot easier to replace than an iPhone screen because the infotainment system doesn't have to be IP68 water and dust resistant - which means it's "probably" held in place with snap fit bezels and/or screws.
    Once you get the head unit out of the car, even an underemployed college grad will be able to replace it, no sweat....and who knows?
    Somebody might have actually thought that an 11" pane of glass in a CAR might need to be replaced.
    You might not have to remove the head unit to replace the screen. ;)
    Oh....
    And don't buy a Tesla.
  8. Salamander_King
    11,024
    8,978
    New England
    One problem is that on PRIME there is no way to turn off HVAC system without the main screen digitizer functioning. You can turn on and control some of HVAC functions using MID and wheel switches, but no way to turn it OFF.
  9. followingalex
    42
    New York
    could you imagine this dude with a Tesla Model 3 where every aspect of the car is on the screen?!
    just pictured this guy punching out his leased Tesla and couldn't stop laughing.. he hasn't responded or been online since the post, so maybe he drove the car off a cliff, good riddance mate.. there will always be a special place in this forum for you.
  10. Mendel Leisk
    42,345
    That's a bit derisive; I feel for the guy.
  11. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    jerrymildred likes this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    It looks like they only work on units through 2009, but maybe they would like to expand to newer stuff. Definitely worth asking them.
  13. Hidyho
    Hidyho Senior Member
    2,699
    531
    2018 Prius
    At least this is a lower price, but not sure its for a 2020, use vin to make sure it fits.
    Display Unit - Toyota (86804-47460) | Toyota Parts
    Also, the damage should be covered by your comprehensive part of insurance if you have it, on a lease you should.
    What does comprehensive insurance cover?
    The word “comprehensive” can be misleading. Comprehensive, also known as “other than collision,” does cover a variety of situations that collision does not. Since the details of comprehensive insurance can vary, it’s a good idea to carefully review your car insurance policy to understand exactly what is covered.
    Comprehensive insurance generally covers your vehicle in these scenarios:
    Vandalism
    Theft
    Glass damage
    Damage from flying missiles (defined as any flying or propelled object, like an item falling off a vehicle) or falling objects (trees, boulders, etc.)
    Striking an animal
    Fire
    Floodwaters
    Damage due to natural events or severe weather (e.g. hail, wind, tornado, or hurricane)
    And at worse, are you sure it wasn't damaged by vandalism? Wink Wink
    #13 Hidyho, Oct 31, 2019
  14. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    If it makes you feel better. That's the same price Toyota quoted me for a replacement nav unit in my 2010 Prius about 6mos ago. The dealer also offered a refurb for $2000. I opted for one off Ebay for $500 and put it in myself.
    I realize your car is much newer so it's harder to find used parts
  15. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Did they change this for 2020? My 2018 has an OFF button.
  16. Salamander_King
    11,024
    8,978
    New England
    On your MID with wheel buttons? I am talking about turning off HVAC function on my 2017 PRIME Premium without using 11.6 inch display. One option is to use voice command, but my experience has been that is even more troublesome than using the 11.6 inch display.
    EDIT: Oh, I see. Maybe on PLUS (or LE) trim with 7" display, there is actual physical OFF button.
    #16 Salamander_King, Nov 6, 2019
  17. PiPLosAngeles
    1,551
    724
    I think perhaps only the base model is arranged this way.
    TGrracie and Salamander_King like this.
  18. Salamander_King
    11,024
    8,978
    New England
    Yap... on Plus (or LE) with 7 inch display, there is a physical OFF button. I want that!
    #18 Salamander_King, Nov 6, 2019
  19. Denwah
    Denwah Junior Member
    San Francisco, CA
    2019 Prius Prime
    Hi The_Ape, when you replaced your center display did you need to have it reprogrammed? or was it just plug n' play?
  20. Denwah
    San Francisco, CA
    2019 Prius Prime
    did you end up getting this fixed? And which method did you end up going with?
