Cracked inside rim, slow leak, and repair
Discussion in 'Tesla' started by bwilson4web, Dec 18, 2025.
  1. bwilson4web
    16,549
    A slow tire leak was caused by an inside, cracked rim (see photo). So I had a 2,000 mile, used, 235/45R18, Tesla Model 3 tire, removed from a spare rim. This used tire is available to anyone who wants it. It's brother will be available in late January if you want the pair:
    After making a cut, the disabled rim will be sold for scrap aluminum. As for the Tesla tire, free to whoever wants it.
    I do not like the Tesla stock tires:
    • too heavy - my Model 3 weights 3,800 lbs and this tire is also used for much heaver models.
    • short life - typically rated at 36,000 miles, my first set barely made 30,000 miles.
    • high tire resistance - squishy, they cause more rolling drag than the ones I use.
    • dynamic instability - in some conditions, these tires develop a resonance with Full Self Driving that is unpleasant and can go divergent.
    I will never drive another mile on Tesla recommended tires. Too costly and in some cases, unstable.
  2. Mendel Leisk
    42,364
    I’ve dealt with model 3 rims/tires: first time I laid one flat on a concrete slab it was alarming to hear a clang, the rim is wider than the tire. Tesla engineers must be aware of this. Or maybe not?
    Lug nut torque value is an eyebrow-raising 129 ft/lb.
    bwilson4web likes this.
  3. mikefocke
    4,083
    1,864
    Sanford, NC
    So what tire do you recommend?
  4. Mendel Leisk
    42,364
    More a case of coming up with a rim that doesn't surpass the spec'd tire in width.
  5. bisco
    52,878
    what do you think caused the crack? i've never seen that
  6. mikefocke
    4,083
    1,864
    Sanford, NC
    There are tires that project outwards just to protect against rubbing the $$$$ rims. My Mich CC2s have such a feature of their design.
  7. Mendel Leisk
    42,364
    Yeah, our 3'rd gen's 17" Michelins are thus, has a ring of rubber projecting further out, about 3/16" I think. Still, with/without this, the Tesla 3 is the first time I've encountered any wheel/tire combo thus.
  8. ETC(SS)
    7,571
    Cracks seem to be a 'thing' with T3s according to the interwebs - although I do not know if this is a design issue or just people who do not know how to avoid potholes.
    The torque spec isn't super crazy but it seems a little high for a fragile aluminum rim.
    IIRC the specs for my truck's 'steelies' is either 110 or 120.
    The wear rating IS interesting.
    Tyres that are 'energy efficient' are usually hard as a billiard ball - meaning you can run over a dime and be able to call "heads or tails."
    Engineering is compromise.
    You trade handling and comfort for 'efficiency.'
    Curious......
