Cracked plastic under the front end
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusNeckBeard, Oct 19, 2016.
  1. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    Backing in to parking space reduces the likelihood of accidents by 30% and you get the help of the rear camera and you will never hang your front end up on the curb.
    iPhone ?
    xliderider likes this.
  2. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    Man, that's economical!
    $18 + your Labor, plus cost of fire extinguisher (should already own) + blocks to drive up on to. Good job.
  3. PriusNeckBeard
    376
    211
    Cincinnati
    Just curious. How much did the procedure cost , and how often do you do it?
    For gen 3, 3 mpg saves $50/ year in fuel costs.
    Paul Schenck likes this.
  4. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Paul clearly puts on more miles than you (or I) do, so he could save over twice that. (y)
    YMMV
  5. Mendel Leisk
    42,376
    The big issue with that front piece: it's tapers down, front to rear, then has an abrupt lip at the trailing edge. If you run it just an inch or two onto a concrete wheel stop, that's bad enough, will put some abrasive gouges in it.
    But go further, enough that the whole piece has passed over the concrete wheel stopL when you reverse and back out, that trailing edge lip often snags on the concrete corner, gets pulled down, torn. A better design perhaps would bevel that trailing edge.
    #25 Mendel Leisk, Oct 23, 2016
  6. Paul Schenck
    524
    307
    Fresno, California
    First time I paid $65 do steam clean of engine and undercarriage. Second time I put the driver side up on jack stands and did my own using a hose from water heater.
    $65. @ 3 mpg $3.50/gallon =34,000 miles
    Every time you change your tires you should pay for a under carriage treatment
    iPhone ?
  7. PriusNeckBeard
    376
    211
    Cincinnati
    Fwiw, that all makes sense except that last part.
    Fwiw, I get:
    (15,000 mi. / 45 mg) x $2.50 = $833/yr.
    ( 15,000 / 48 mpg) x $2.50 = $781/yr.
    The difference is $52 /yr.
    Would a cleaning last a year?
    If so, the savings would be, we hope, $52.
  8. Mendel Leisk
    42,376
    Don't want to step on toes, but I can't underbody cleaning doing anything for mpg. For starters, if I look at the underside, mostly smooth plastic panels, it's all quite clean, without any special attention.
  9. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Any wildlife hung up under there really breaks wind. :eek:
  10. Paul Schenck
    524
    307
    Fresno, California
    Back in!
    iPhone ?
