Cracked Rear Wheel area near flap
Discussion in 'Gen 4 Prius Main Forum' started by PurcellvillePinball, Mar 21, 2017.
  1. PurcellvillePinball
    30
    27
    Purcellville, Virginia
    Four Touring
    my 2017 Prius Four Touring is just over 3 months old. I noticed that the plastic at the flap to the rear passenger wheel is broken. I assume this is due to typical road debris.
    This is disappointing. This area should be made of material that can handle road debris. I assume this is not covered under the regular warranty or extended platinum warranty.
    I have only driven on roads and have not hit anything.
    Thanks
    Michael
  2. JC91006
    16,936
    8,647
    Bring it to the dealer and tell them it's an inferior part, should be covered under warranty
    PurcellvillePinball likes this.
  3. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    Your insurance should cover it under comprehensive coverage.
    Hopefully your deductible isn't that bad.
    You could always epoxy it.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    If there are no impact marks on or around the crack area, then it's a manufacturing defect, covered under the warranty.
    RCO likes this.
  5. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    To do that kind of damage it look like it was hit. I think the dealer will say that's what happened.
  6. PurcellvillePinball
    30
    27
    Four Touring
    I brought it to the dealer. The service person said that I hit something or ran over something that pushed the flap back and caused it to break the side of the car.
    I called Toyota Care and sent the above pictures to them as well. When I called, they said to take it to the dealer to evaluate. They have not seen the email and photos I sent yet. It can take up to a day to post...
    The service person stated that I should call Toyota Care and see if they can do something. (I seem to be in an infinite loop.)
    Did I run over anything I felt? No. Did I run over something or some road hazard cause it? Probably. Is this the quality of the cars we now have to accept? My 10.5 year old Prius with 215,000 miles never had this kind of problem.
    You would think something that hangs down would have some play and not cause the side of the car to break.
    I love my Prius. And I will live with a crack for the next 10 years or so. It would just be nice to have cars that are not made of plastics, like toys.
    I was hoping others would have similar problems that we can keep track of and see if this becomes an issue.
    Thanks
    Michael
  7. Mendel Leisk
    42,332
    Yes. There are lot of minor changes they could make to mitigate what happens with little "love taps". They're likely right, that low hanging spat likely snagged something, and leveraged at it's connection.
    See if you can get the spat off, and wheel well liner, loosen things up to get at the backside, put in some fiberglass mesh and a two-part bumper repair bond. This is something I've used, but maybe just a Canadian product, not sure:
    Fiberglass mesh and any two-part epoxy, JB Weld or whatever, would work I think.
    RCO and PurcellvillePinball like this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Possibly something/someone hit it while it was parked. :(
    RCO likes this.
