Cracked Trunk Trim Piece - Not Warranty Covered?
Discussion in 'Gen 5 Prius Main Forum' started by Poseidon, Dec 5, 2023.
  1. tahufive4
    tahufive4 Junior Member
    2023 Prius
    2023 Prius at ~7,500 miles here with a crack. I took it into the dealership and they claimed there was "outside influence" and thus isn't covered under warranty. I'm taking the car back in next week for an unrelated issue and will follow up with them.
    The service manager said to call Toyota Customer Engagement directly and open up a case with them. I've contacted Toyota and provided links- we'll see what they say.
    GcinFl and deev like this.
  2. Michael Capron
    Michael Capron New Member
    Monroe, NC
    2023 Prius
    [ IMG_1037.jpeg Same issue here. Taking to dealer to find out of covered?
    QUOTE="Poseidon, post: 3410314, member: 206831"]Hi all,
    A month ago I started noticing a crack on a trim piece on the trunk of my '23 Prius, and later found a few other folks on Reddit that had similar issues. Car was driven normally, but I suspect bumps may have caused that plastic piece to start cracking, which grew over time. I took my car in today for my 10k service, and was surprised to hear that this is not currently covered under warranty, and that (according to my service rep) it would cost 1k USD to fix. The rep did mention they would have their warranty manager reach out to Toyota to see if this is a known issue, but for now, I'm out of luck.
    Does anyone else have the same issue with their '23 Prius, and if so, how has your dealer responded?
    Pics attached below for reference:
    [​IMG][/QUOTE]
  3. Michael Capron
    Monroe, NC
    2023 Prius
    It’s covered under warranty. Took mine in today part will be in next week.
    HacksawMark and BiomedO1 like this.
  4. Mendel Leisk
    41,402
    That's good news. Any documentation, reference of some sort, for others?
  5. nagrath
    nagrath Member
    145
    49
    Putnam County, New York
    2023 Prius Prime
    XSE
    My 2023 Prime cracked in exactly the same manner. There is no support under it so it flexes whenever the hatch is closed. I tried to superglue it but the plastic doesn't bond. Have not asked Dealer about it but this will embolden me. If they changed the design to provide more support it is evidence that they know it is a problem.
    #85 nagrath, Sep 22, 2024
  6. Hammersmith
    Hammersmith Senior Member
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Just a general tip: If you ever worry about plastics bonding with superglue, use one that comes with a primer.
    I use this one just because it's easily available locally for me, but I'm sure there are other options:
    Loctite Super Glue Plastic Pen
    I always had terrible luck with CA glues until I started using them with primers.
  7. nagrath
    nagrath Member
    145
    49
    2023 Prius Prime
    XSE
    Yes, please check the receipt to see if they reference any service bulletin so that we can refer to it when dealing with another dealer if they balk about coverage. It's nice, but unfortunate, to know others are having the same problem. I thought I was going crazy.
    daisy555 likes this.
  8. nagrath
    nagrath Member
    145
    49
    2023 Prius Prime
    XSE
    I HATE that cover! I keep hoping for an aftermarket replacement.
    Gokhan likes this.
  9. fosburg
    fosburg New Member
    Vancouver BC
    2023 Prius
  10. fosburg
    fosburg New Member
    Vancouver BC
    2023 Prius
    Same issue on our 2023 XLE AWD. 15000 km, but unsure when crack occurred as only noticed when washing the car. Dealership has forwarded to Toyota Canada, hopefully a positive response this week.
    Fosburg
    Vancouver
  11. fosburg
    fosburg New Member
    Vancouver BC
    2023 Prius
  12. Downrange
    Downrange Active Member
    372
    212
    2024 Prius Prime
    SE
    Still no service bulletin to reference? Wife had to eat the cost of her 23 Prius AWD, dealers and Toyo central are not budging on this. Class action suit time?
  13. Zeromus
    Zeromus Active Member
    553
    307
    Ottawa Canada
    2024 Prius Prime
    SE
    IDK if there would be enough people to get a Class action going, or if it would be worth the cost to be honest.
    But I'd just keep annoying corporate, and I'd instead work with others online that have reported the issue to also contact corporate.
    They probably need to have a lot of people, with the same problem, in the same spot, with the same general presentation, and proof of repairs that were (or weren't) covered to come together and show them its not just a one off.
    It might not be super common, but it is a flaw.
    On the plus side, I believe toyota has retroactively refunded people for issues that weren't noted in a TSB until after it was deemed a manufacturer's defect for other car problems in the past. so keep records and receipts.
  14. Mendel Leisk
    41,402
    Do remember how Toyota treated you, next time you're car shopping. Not sure if the competition is any better, but it's at least satisfying.
  15. purplePriii
    purplePriii Active Member
    275
    122
    From the dealership experiences, sometimes I wonder if I wouldn't have been just as good with a Kia!
    Toyota USA seems slightly better than Toyota Canada. Maybe we should make a thread elsewhere asking who had the better experience with which corporate car manufacturer when it came down to issues.
    daisy555 and Mendel Leisk like this.
  16. tahufive4
    2023 Prius
    I ended up sending a direct email to Toyota Corporate asking for a resolution. I included a link to this thread, and multiple links across the web of other people facing the same issue. They called me back after a couple of days and said that they'd send out a field technician to look at it. This is currently waiting to be scheduled.
    I'm not hopeful that Toyota will stand by their product: the representative who called, while polite, wanted to set expectations that if it's deemed by the dealer and technician as outside influence then their findings stand. It'll likely be the same loop of "we're not going to cover it because we don't want to admit that this part was poorly engineered". When I pointed out the at least 10+ instances of this issue occurring across the internet the representative said that Toyota has to take this on a case by case basis.
    For those of you who had this issue, regardless of whether it was fixed under warranty or not, please help reach out to directly to Toyota Corporate so they can document it and hopefully issue a service recall of some sort.
    This has been a huge headache and waste of time for me and I genuinely hope Toyota stands by their products on this. We'll see how this process plays out.
    GcinFl, mva and Mendel Leisk like this.
  17. Paul Gregory
    Paul Gregory Senior Member
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I've got the same thing on my '24 (sorry, no pics) and I'm currently at the dealer for scheduled maintenance, and I showed them the issue. I'll post the answer they give me about it, but if they refuse to replace it, they'll have a fight on their hands.
    Post edit: they said they would forward the issue to the service manager (whatever that means).
    I tried to post a picture, but nothing happens when I click on the icon.
    #97 Paul Gregory, Dec 17, 2024
  18. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I liked the old roll-shutter type cargo cover on my Gen 3, but I have to admit that the newer, simpler one works just fine.
  19. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I know I didn't cause it, and I doubt anyone else did. My theory is that it cracked from the vibration of closing the trunk.
  20. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    Good news. I just heard from the dealer, that the trim piece will be replaced under warranty.
