Cracked windshield water reservoir
Discussion in 'Gen 3 Prius Main Forum' started by abdullah arslan, Oct 3, 2023.
  1. abdullah arslan
    189
    79
    is there a way to reach the reservoir from the bottom without taking apart many things? Deeply appreciated.
    There must be a small crack around the middle in terms of height. It spills after some point when you fill it
  2. PriusCamper
    PriusCamper Senior Member
    13,316
    5,390
    Pacific Northwest, USA
    If you can find a wrecked Prius you can pull parts off of, that'd be the easiest way to figure out its removal and also least expensive way to replace it.
