Cracks in tail light, repair or replace?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by czhuang, Jan 7, 2018.
  1. czhuang
    czhuang New Member
    New York
    Hello everyone! I have a used 2012 Prius c and this morning I noticed some small, thin cracks around the exterior of one of my tail light covers. There's three about the length of a quarter on the plastic part and you can see them but not feel them. There's a fourth one on the silver side part, underneath the plastic exterior I think.
    I'm a total newbie, so I'm wondering whether or not I should be concerned about these small cracks at all, and if it needs to be repaired/replaced? The cracks happened because I was trying to change a tail light bulb that burn out and DIY isn't really an option because I live in a super frigid area. I'm concerned about water getting in as we get a lot of snow as well.
    Thanks so much!
    49,504
    welcome!
    you could try some silicone and see how that works. keep an eye on them for moisture inside.
  3. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Depends on the nature of the crack. Is it hairline kinda crank?
    If the crack is so severe, you need to replace them, because you might have to be replacing the taillight bulbs now and then, because they'd keep corroding and ...
    Can post a picture or so?
