Cradle for EVSE
Discussion in 'Prime Plug-in Charging' started by mveras1972, Aug 31, 2019.
  1. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    if it's raining of snow is drifting where I usually have my brick, I'll run an extension to my mailbox and drop the brick in there.
    It got me wondering about a bigger mailbox used as an outside home for the brick and cable. Big question now is 120 or 240 inside the new mailbox.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    By now, I would have made my own out of scrap sheet metal if I wanted it to be pretty and removable. Probably just wrap around the post and then drop down to a couple pins to hang the brick on through the holes provided for that purpose.
    What I did at work as even easier. I just ran a wood screw with one of those tiny torx heads into the wood since my "charging station" is behind the pump house and WAY out of public view. I hag the brick from the screw via one of the holes in the brick. I think it took about 30 seconds.
    Raytheeagle likes this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  4. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I am looking forward to seeing the final result.
    Rob43 (y)
    mveras1972 likes this.
  5. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    I got an idea using a couple of tool hanging hooks. Might work on that tomorrow.
    iPhone ?
  6. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    I just use a bungee and the eye holes. Cheap and works fine. Somethings you don’t need to over think.
  7. vvillovv
    4,337
    1,519
    NY
    simple and effective with full suspension system !
    please post pics if you have any easily available. :)
