Crank Sensor Location
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by laivindil, Jul 20, 2017.
  1. laivindil
    laivindil Junior Member
    Norfolk, VA
    Purchased a new Crank Sensor (Toyota part # 90919-05087) for my 2004 Prius. Searched the forum, and the interwebs, and cannot seem to find the exact location of the sensor.
    Anyone have a pic or diagram of its location? Thanks
  2. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Left side of engine in the front towards the grill 1st wire you see going down on the left side of The engine And the boat just below that is the filter Needs to be clean too behind bolt
  3. laivindil
    Norfolk, VA
    Left side... do you mean passenger side? As in the same side with belt and water pump?
  4. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  5. Patrick Wong
    18,210
    6,515
    The crank position sensor is very near the crankshaft pulley, passenger side of the engine. One bolt holds the sensor to the engine block. Raise up the front of the car to have adequate access to get under the engine, then you can easily see the sensor.
    m.wynn likes this.
  6. laivindil
    Norfolk, VA
    Thanks guys. :)
  7. Patrick Wong
    18,210
    6,515
    What were the circumstances leading to the need to replace the sensor?
    jerrymildred likes this.
  8. laivindil
    Norfolk, VA
    Error code and dealer diagnostic. Could end up being the timing chain, but I will stop at the crank sensor. I have over 300,000 miles (odo stopped at 299,999 in 2015), so it is not worth the money and effort to replace the chain if that is, in the end, the real issue. I will drive it until it blows up, sell it for parts, and buy a lower mileage used Prius.
    Raytheeagle and Patrick Wong like this.
  9. Jakl2008
    Jakl2008 New Member
    Waterloo NY
    Remove the passenger side front wheel. Remove or move the plastics shroud out of the way. It’s that easy. The diagram on the internet to its location is wrong.
  10. Jakl2008
    Jakl2008 New Member
    Waterloo NY
    The diagram isn’t wrong just difficult to read. It looks like it’s by the exhaust manifold. Enlarge the pic and you will see it’s on the passenger side of the engine lower near the crank pulley.
