Crazing banging noise but goes away when in reverse
Discussion in 'Gen 3 Prius Technical Discussion' started by Mr. Potato, Nov 20, 2018.
  1. Mr. Potato
    Mr. Potato New Member
    FL
    People have trouble recognizing the car from the software? For the mean time I’ll clean the egr and intake I suppose
    Raytheeagle and PriusCamper like this.
  2. PriusCamper
    PriusCamper Senior Member
    13,468
    5,437
    Pacific Northwest, USA
    The original techstream OBD2 reader (mongoose) costs many hundreds of dollars... Hacked software and devices from China makes it easy to get past that, but you still have to get past that...
  3. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    The ones I have seen came with the cable and software...
    And it will be worth it. It was worth it just to turn off that stupid back up beep!
  4. Mr. Potato
    FL
    The one I got online was $60, would it still work?
  5. PriusCamper
    13,468
    5,437
    It should... As I said before, get familiar/do reading about some of the challenges people face setting them up.
  6. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I have heard that noise before. That’s a dead cylinder. Engine disassembly or replacement is going to be required. This was how mine ran with a bent valve on #1 cylinder.
  7. Mendel Leisk
    42,355
    In reverse the engine's just idling IIRC, that maybe ties in?
    @cnc97's had his engine out more times than he can count one hand, if I'm not mistaken? (y)(y)(y)(y)
  8. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I thought it was 4 times ;).
    But the number of appendages mAy determine if you need an additional hand or not (y).
  9. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I was going to upload my video, but it’s too long. I may put it on my YouTube and link to it later.
    amos and Raytheeagle like this.
  10. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
  11. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    As a comparison, this is how it sounds now.
    Robert Holt, amos, RMB and 1 other person like this.
  12. Sjonniestylo
    Sjonniestylo New Member
    Rotterdam
    Hello i am from the netherlands. Yesterday i was talking with a toyota mechanic.. it is the head gasket who is leaking.. so now maybi your valve is bent...
    You have to replace your engine... you can drive the car in mechanic mode.. thats only driving with patrol... not electric mode... do you know how to put in mechanic mode?0
    PriusCamper likes this.
  13. Mendel Leisk
    42,355
    Special modes are really only for maintenance, not driving, might damage the transaxle, more damage than you currently have. I would drive it just the minimum, or park it and find alternatives till a replacement engine is available.
    m.wynn likes this.
  14. Wing Twister
    Wing Twister Junior Member
    Pakistan
    Hello experts, just experienced same issue with my prius yesterday. I started my prius after a week of inactivity. On very first start same noise observed from engine, i immediately put the car in reverse and with a light jerk the nose disappeared. Thanks God the nose didn't appear after that. In my opinion such noise appear due to some incomplete mechanical action inside the transaxle.
    If such noise is due to engine then it wouldn't go away even in reverse, so my suggestion is that instead of focusing on engine for noise, firstly transaxle may be investigated. I'm sure all prius owners know that transaxle fluid must be replaced after a certain mileage (may be 50000 miles or so but not sure).
  15. padroo
    padroo Senior Member
    2,763
    2,253
    I noticed the original owner was obcessed about the 20 w 30 oil. While not ideal it won't ruin your high mileage engine if ran for a short time. Four cylinder engines don't run well with a dead cylinder. You have fairly high mileage on the engine and a cylinder leak down test will help determine the health of the engine and it sounds like it is already an oil burner. How often do you check your oil?
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    See post #6, 1st sentence will let you know transaxle is out of the equation.
    Raytheeagle likes this.
  17. Mr. Potato
    FL
    You’re engine is f#%ked (basically). It may be a dead cylinder because of the EGR read top comments if that doesn’t fixing it then your misfires are due to a major break down mine was a piston 4 ring hope yours is a little better
  18. Mr. Potato
    FL
    I would like to update everyone about this mystery noise. The initial cause of my problem was that my mother ran low on oil and didn’t do anything when the light came on. Eventually it lost power and she pulled over. Then it was too late it had already ruined a piston ring. At the mileage the engine is at (170k) it would be a waste to rebuild. Still looking for an engine if someone knows someone that’s selling one I have not been able to locate one since. My car has just been at a shop sitting there. If you hear this noise to head straight to the junk yard to find an engine it may be your EGR system because it will cause a misfire. I am still curious as why the engine would run fine in reverse?
  19. Mr. Potato
    FL
    Yeah it was an oil burner and It’s time came it burned a little too much and it wasn’t filled back up and left good bye
  20. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    See post #6 - first sentence.
