Crazy noise plus sudden drop in mpg's
Discussion in 'Gen 3 Prius Fuel Economy' started by kbye, Nov 11, 2012.
  1. kbye
    kbye New Member
    First time Prius owner Aug 2012. First 2 tanks of gas very impressed at 50-51 mpg. Then going slowly (10mph) through a parkinglot I heard a strange noise on passenger side underneath the car. The best description is that it sounded like a steel lawn rake being dragged under the car on the asphalt. It lasted for about 30 seconds, then quiet and I have not heard it since. No sign of issues. No dash warning lights.
    My next tanks rendered 47.5, 48.5, 46.5, 45.75 mpg. Then in the last 2 tanks suddenly at 41.5 and 42.75 mpg. This seems like a very major drop in mpg. I have been reading the comments regarding outside temp etc. and I will make adjustments. It just seems extreme and the "noise" is now making me wonder if some electrical component failed and is adding to the poor mileage issue. Anyone with a similar event or experience? Thanks!
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    You probably want to check under the car and see if you are missing an under-engine cover. This may explain the noise but not the drop in mpg.
  3. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    I saw my mileage go all over the place before I hit 10k in milage. At 23k now (in 9 months) and I'm getting 50mpg, and no less that 47. I am in ECO mode. Your best bet is judging from gas in vs mileage. It also sound like you oil change door may have fallen of, check into the dealer.
  4. PriusCamper
    PriusCamper Senior Member
    13,277
    5,363
    Pacific Northwest, USA
    As for the noise, I once had something similar that wouldn't go away until a friend gave the end of my exhaust pipe a real hard shake and it hasn't rattled since. Meaning the exhaust system has some heat shielding that can make that kinda noise.
    As for the MPG:
    I'd avoid Toyota dealers when it comes to addressing these kind of fluctuations in MPG, it's not what they do. In their eyes your car has no problem.
    That being said, your decline in MPG could be any number of things, or a combination of things... Your decline in mileage is consistent with the change in seasons, maybe a wee bit more severe...
    The bright side is you now have a great opportunity to spend time checking everything out and learning more about your car: Tire pressure? Reboot? (disconnect 12v battery, wait, then reconnect), air filter? too much oil added? heavy reliance on heater and defrosting mode? dirty air flow sensor? drivetrain/alignment changes? State of charge of both batteries?
  5. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  6. PriusCamper
    13,277
    5,363
    Excellent insight thanks... cwerdna
    Here's the quote I like the most:
    "here's a sneaky illusion in mpg numbers. Consider: If your pickup rated at 10 mpg gets only 9, you shrug and say it's off only 1 mpg. But if you drive a hybrid labeled 50 mpg and it drops the same 10 percent to 45, you complain of lousy mileage. The illusion tricks you once again when you think of mpg instead of the fuel you actually burn. Hybrids are chosen by people who think saving gas is right up there on the list of American virtues with motherhood and voting. But when the hybrid gets 45 mpg instead of the expected 50, a 100-mile trip consumes less than a quarter of a gallon more than expected. Compare that with the pickup that gets 9 mpg instead of 10; its 100-mile trip burns 1.1 extra gallons."
  7. Former Member 68813
    3,524
    983
    US
    You mean you have been dragging a bike under your car for several tankfuls and never bothered to look under your car?
    PriusCamper likes this.
  8. nyty-nyt
    nyty-nyt Member
    139
    Ontario
    I just had the noise develop 2 weeks after an oil change. I ripped the door off finally, as it was pretty much destroyed by the time I pulled over to see what the problem was.
    I never suspected that this might be an issue with the car, but I see lots of discussion and the design seems to be inadequate.
    Now I have to see if the dealer will replace it at no charge to me.....
    Wish me luck, as the dealer is a greedy b*****d where I live.
