Crazy sound upon ICE startup
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Nougatti, Nov 9, 2016.
  1. Nougatti
    Nougatti Member
    119
    59
    Norway
    Cold soak in this respect mainly means shutting down the engine too quickly after a startup (before getting warm) and the next startup having "the noise".
    iPhone ?
  2. Nougatti
    Nougatti Member
    119
    59
    Norway
    iPhone ?
  3. Nougatti
    Nougatti Member
    119
    59
    Norway
    iPhone ?
  4. Nougatti
    Nougatti Member
    119
    59
    Norway
    Cold soak in this respect mainly means shutting down the engine too quickly after a startup (before getting warm) and the next startup making "the noise".
    iPhone ?
  5. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    Well, just happened again today on a lunch run. Didn't stop when I reached my destination (though it was less than a mile away). Booking a service appointment...
    #25 iluvmacs, Dec 15, 2016
  6. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Crazy!
    My 2010 did this; it was very repeatable. My 2012 Plug-in has never done this.
    It has to be software related. I bet there's an ECU update the dealer can apply which will solve this problem. I did note on my service records that my dealer did apply a "Special Service Campaign," but never told me what it is.
  7. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    I had same problem and really cold days on start up. It also occurred when the engine was warmed up. Mine was a failing intake timing gear. Replaced and it is quiet again. No more rattling sound coming from engine.
  8. Mendel Leisk
    42,345
    Intake camshaft timing gear?
  9. Victrola
    Victrola New Member
    Michigan
    Could a failing intake camshaft timing gear produce a p0304 code?
  10. Mendel Leisk
    42,345
    I was responding to previous post, didn’t understand that terminology. I’d suspect something was lost in translation, talking with service writers, but not clear on it myself.
    Can you add more background regarding P0304 code; what’s the car doing? What’s the miles on it?
    Victrola likes this.
  11. Victrola
    Victrola New Member
    Michigan
    224000 miles on it. 2010. recently cleaned the egr tube and intake manifold in response to a p0401 code which cleared that code. I thought this would address the rough start up, but it did not. I did not clean the ERG valve and am considering cleaning that and am currently trying to figure out how to get the obd reader to move the valve to ensure it is not stuck open and it functioning properly.
    After this, the car threw the p0304 code. I have switched the 3rd and 4th ignition coil and cleared the code. P0304 popped up again. I put a screw driver to the fuel injector and it seems like they all function, but the 4th one does seem to be struggling.I think I am going to switch 3rd and 4th injector today to see how they look and if that moves the code. I had the spark plugs changed 6 months ago, but havent been able to get the spark plugs out yet this time myself.
    All symptoms include:
    -Whining from the radio which is decreased by turning the radio off
    -rough start up especially if cold started, 'knocking'
    -high vibrations in center counsel and passenger seat, particularly in the 2nd notch of the hybrid indicator system on the dash
    -occasional hard acceleration in that same 2nd notch (putting the car to the red spot -so full gas- stops the hard acceleration)
    -the first acceleration of the car seems to be sluggish
    -currently getting slightly decreased gas mileage
    I also am aware of a small valve cover leak per the mechanic who changed my spark plugs 6months ago. I did not change the intake manifolds gasket either as I did not initially plan to take it off, but maybe that's leaking enough to cause a misfire code?
    Car also threw a B1443 code which I have not looked into yet, but have just not been using the AC/heater.
    (sorry, I didn't realize at first that I had hopped to a Gen 1 room)
  12. Mendel Leisk
    42,345
    224k is late in the day for EGR cleaning. With everything you’ve described, very likely head gasket is failing.
  13. bisco
    52,855
    Gen 1 plug in, so it’s the same engine
  14. Victrola
    Victrola New Member
    Michigan
    I got the prius at 210,000 and mostly trying to keep it for another year or two until I can hopefuy get a newer model.
    I got the spark plug out, and it looked fine. Haven't touched the Injector yet because I realized I needed the oring.
    I was thinking head gasket potentially, but there's has been no coolant loss, no white smoke, no milky oil. Would this potentially be catching the gasket early enough that I could have the gasket replaced or is it more like by time you have the problem the connecting rod is likely already bent?
  15. nicoj36
    nicoj36 Active Member
    518
    162
    I'm not a fan of ICE turning on in the middle of EV at high-speeds. If I know I'm gonna use ICE, I just start the car in non-EV mode to give the ICE a proper warm-up.
