Critic's DIY Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Mar 15, 2012.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    My 2011 is nearing 30,000 miles and I plan to change out all of the fluids at that time.
    Would you folks be interested in a video for each service? They would be live, narrated videos on how to perform each service.
    These are the services that I think I will video:
    1) Transaxle drain and refill.
    2) Engine Coolant Replacement
    3) Inverter Coolant Replacement (with Techstream Lite)
    4) Brake Fluid Flush (with Techstream Lite)
    5) PCV Valve Replacement
    6) Throttle Body Cleaning
    7) Front and Rear Struts/Shock replacements (at 50k)
    Tips, suggestions and comments are all appreciated. I am at 26k right now, so it will probably be another two months before I reach 30k.
    :rockon:
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I think it would be pretty sweet. Go for it!
    My suggestions:
    1) Incorporate a pretty girl assistant
    2) Dress her appropriately for the position
    3) I had other ideas but promptly forgot them after listing 1) and 2)
    4 people like this.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I'd do just transaxle change and spend more time with the girl.
    2 people like this.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I have been leery of replacing the ICE radiator fluid out of fear of trapped air. I wish I had a TechStream like you.
    Have you read Hobbit's monograph on Prius brake fluid ?
    Your maintenance (2), (3), (4), (5) seem very early to me. No harm of course, but I doubt any benefit.
    (7) is hard, if the accounts some people have posted are close to true. That is the video I'd love to see, but think twice before tackling this job unless you are really confident from past experience.
  5. The Critic
    3,193
    2,333
    CA
    But I am doing this for academic purposes!
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That video may require an adult rating and not be fit for YouTube. :rockon:
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Depending on the girl it could be very academic!
    *walks away singing Van Halen "Hot for Teacher"*
  8. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I would be interested in the videos, esp if you include the TechStream navigation parts. I just did my oil change at 32k and debated doing the Transaxle but just haven't gotten around to it.
  9. dogfriend
    7,512
    1,191
    Carmichael, CA
    PCV valve replacement seems way too early. You could check it (its supposed to rattle if the check valve is working properly) and possibly clean it with solvent, but replacement seems like a waste unless it isn't working.
  10. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Go for it !! Thanks !
    Especially the transaxle fluid change. I got that coming up. :D
    REV
  11. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    If you are going to spend more time with the girls, I would recommend headlight inspection first and then fluid drain with a full flush. :D
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    And latex!!!
  13. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Those of you saying it's too early to replace something are missing the point. The Critic is simply doing it for educational purposes and having those videos would be great for DIYers. They're not going to be too X-rated due to the Critic's lack of "gunk" at 30,000 miles but I'm looking forward to seeing the girl.
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    At 30k miles, it is time to replace the engine air filter and cabin air filter.
  15. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I would be interested in seeing all of the videos. I'm sure other will to for years to come.
  16. jjPrius
    jjPrius Junior Member
    68
    22
    Southern California
    The video suggestions sound great. I think the PCV valve is covered under the CA Emissions Warranty for 15 years / 150k miles, but details may be helpful for our non-CA members.
    Do you have the Mongoose cable?
    Jeff
  17. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    These videos would be awesome! We'd absolutely love to see them. Some others to consider:
    -- Engine oil change (although there may be a lot of these already)
    -- Parking brake adjust
    -- Brake pad replacement (I'm not clear whether it takes any special tools to do this on Prius)
    -- Sound proofing/rattle fixing a Prius
    -- Dash teardown for car stereo install (maybe only applies to Prius II/III)
    I noticed in your maintenance log that you didn't try my 80 cent rattle fix, which is to remove the spare tire and the foam beneath it, wrap that styrofoam piece in a piece of felt, then replace the spare tire. As a bonus, line some of the jack tool tray with felt as well. Wrapping the styrofoam beneath the spare tire makes a noticeable difference and is really easy. I'd love to do one of these with you. I can't get a car in my garage but I have a pretty good set of tools.
  18. The Critic
    3,193
    2,333
    CA
    I have the knockoff Mangoose cable.
    I have done the parking brake adjustment before and can certainly make a video on it.
    For the brake pad replacement the service manual is a bit unclear, but it seems like you will need to use Techstream to do a linear valve offset.
    For the stereo install we will have to sublet that job to F8L. :cool:
    I will let you know when the time comes closer. Right now, I am at 26k so it will be another two months or so.
  19. Rebound
    3,996
    2,645
    Portland, OR
    I've done brakes on all my other cars, since 1982, but I'm confused about what's needed with a Prius. That's why I'd love a video.
  20. Rebound
    3,996
    2,645
    Portland, OR
    Why? You have a Prius III, it could use a radio upgrade. I've done one on my 2010 Prius II.
