Cross Wind Problem
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 13PriusPete, Sep 6, 2014.
  1. 13PriusPete
    13PriusPete New Member
    New York
    I have a 2102 Plug-In. I feel that the car is very light and in the winter in NY with any winds, the car is pushed. Is anyone else experiencing this problem. I was thinking of trading in the car.
  2. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    What tires are on the car? If it's the OEM tires, I wouldn't be surprised.
  3. Okinawa
    Okinawa Senior Member
    1,333
    320
    It depends on whether you want a smaller car or a bigger car. That is the way I see it. I had a 2011 Prius that I had for 3 years and put 48,000 miles on it. It was a fantastic reliable car that did more than it was supposed to MPG wise. I just wanted a bigger, comfortable car and I bought a 2014 Avalon Hybrid XLE Touring. No regrets at all. It was well worth it to me but it is just what you are happy with. A smaller car will not handle like a bigger car.
    13PriusPete likes this.
    52,773
    is it winter in new york already?
  5. Okinawa
    1,333
    320
    Pete knows it won't be long, just like me in a Chicago suburb.
  6. bisco
    52,773
    i'm already dreaming of florida...
  7. Okinawa
    1,333
    320
    Especially after last winter, so am I. Chicago sucks in the winter. In Boston, not so great either in winter. The older I get the worse it gets.
  8. bisco
    52,773
    exactly.
  9. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
    Have you ever owned a 3100 pound car before your Prius that did not experience this problem as much? What make/model vehicle have you owned that was more stable in lateral winds?
    If it means more to have a potentially heavier, lower-mileage car that is more stable in high winds, then you should replace your Prius.
    #9 KennyGS, Sep 6, 2014
  10. mrbigh
    3,686
    699
    Long Island, NY
    I had been driving Prius family of vehicles since 2005 on Long Island and really I can complaint on driving such an small and light vehicle.
    It survived high gusty winds and flooded areas like a champ. Cornering at higher speeds is another subject on the placebo effect....
  11. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
  12. AK Prius Nut
    AK Prius Nut Junior Member
    Or you can load up with several 50 pds of sand bags in the back for those extra windy days! That should help out with stability.
  13. xliderider
    8,140
    3,278
    Honolulu, HI
    A dead body works too. :whistle:
    SCH-I535
  14. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    But tends to smell after the first 500 miles.
  15. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    We get worse winters, worse snow, and worse winds. The Prius is fine. It is a tall vehicle for such a car and so the winds do blow upon it. As long as your hands are on the wheel and not on the cheeseburger and cellphone steering with your knee, I can't imagine this being a problem.
    retired4999 likes this.
  16. drash
    drash Senior Member
    2,597
    1,338
    Upstate NY
    XLE AWD-e
    I use the PiP in my neck of the woods with 120 inches of snow every year and as much as 175 with the PiP. I use snow tires (the very same ones I used on my Gen II Prius) and never been stuck or had uncontrolled slides. Its about 300lbs heavier than my Gen II but I've averaged 20 mpg more during the winter, and over double the MPG lifetime.
    If you were to put those sway bars on as others have suggested, it'll become more stable, balanced, and a little heavier in the areas I believe you are looking for.
    iPad ? HD
  17. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    Don't sweat it Pete- I did just fine with my 2012 PIP on my 56mi daily commute via the LIE last winter (and during tie 2012/13 winter too).
    Don't be cheap- put real winter tires (I used the Michelin X-Ice) and you'll be fine with the PIP.
    mrbigh likes this.
  18. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    Haven't had problems with crosswinds, but a few months ago I did get an extra 1/2 mile of ev range boost from a 20 knot tailwind during a windstorm.
  19. Astolat
    Astolat Member
    229
    73
    Guildford UK
    And a TARDIS...?
    (Sorry. But somebody had to...)
    Chazz8 likes this.
  20. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    No matter how light the vehicle, they don't REALLY get blown around much except with winds SO strong that you shouldn't be on the road in the first place.
    Most of the movement is just driver perception that causes over correction which is what really makes it move sideways.
