Cross Wind Problem
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 13PriusPete, Sep 6, 2014.
  1. Beachnut
    Beachnut Member
    185
    43
    I found with our new 2014 Pri that by pumping the stock tires up to 42 front, 40 rear, they quit "drifting" around as much and stayed much more planted in the lane with little steering wheel effort. Maybe just try going stiffer with your tire pressures...
    13PriusPete likes this.
  2. 13PriusPete
    13PriusPete New Member
    New York
    True. Thank you. Love the car but at times, especially in higher winds, I feel unsafe. I apprecaite your response.
  3. 13PriusPete
    New York
    Yes, they are the OEM's
  4. 13PriusPete
    New York
    Almost and if it will be like last winter, which i hope not...uugh!
  5. 13PriusPete
    New York
    I have had different vehicles, before the Prius, a 2003 Hyundai Elantra GT, superb car which had over 325,000 miles on it. Did not experince the problem with lateral winds like I do this car. I also owner a BMW and Chevy. No issues.
  6. 13PriusPete
    New York
    Thanks. I have but not past recommend pressure. A friend did this on another car and his tire blew. I wonder if the 2014 Pri pressure rec. may be different. Mine calls for 33/35.
  7. bisco
    52,848
    well, i've run my 3 pri at 42/40 with a total of over 100,000 miles and never had a flat. knock wood.:cool:
  8. 13PriusPete
    New York
    Thanks. I am more than willing to try it! If it helps, great! :)
    retired4999 likes this.
  9. Beachnut
    Beachnut Member
    185
    43
    Check the writing on the side wall of your tires, it will say what the maximum pressure for that tire should be. My stock tires are ratted safe at a max pressure of 44 psi, for carrying a maximum load, so 42 front, 40 rear, cold tire pressures are below that 44 max recommended pressure.
