Crossed jumped cables need some guidance
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Johnny KIlo, Dec 19, 2014.
  1. Mike500
    Mike500 Senior Member
    2,593
    767
    The OP's post 'splains it all.
    Even when the car won't start, most always, there is enough power to unlock the hatch.
  2. Patrick Wong
    18,210
    6,517
    I don't understand the OP's observation, since the dedicated positive jumpstart terminal is covered with a red plastic cover.
    How can red be confused with black? Unless the original plastic cover had been damaged and replaced.
  3. Mike500
    2,593
    767
    All I know is that ALL Prius cars have NEGATIVE grounds. At the battery, there is NO confusion, since the terminal from the NEGATIVE cable always connects to the body of the car.
  4. Patrick Wong
    18,210
    6,517
    Some people manage to botch the jumpstart whether performed at the battery or at the main relay/fuse box. Not all recognize or care that all vehicles (since the 1950's) have negative-polarity ground.
    If you know that all vehicles connect the negative side to ground, then it shouldn't be a leap to recognize that the negative jump cable should connect to unpainted body metal such as a front strut nut. And if the negative cable is properly connected at both vehicles, you would have to try pretty hard to cause damage with the positive cable.
  5. Johnny KIlo
    Johnny KIlo Junior Member
    52
    Chicago suburbs
    Patrick,
    Mine is actually black, it must have replaced
  6. Johnny KIlo
    52
    Chicago suburbs
    Let me elaborate some more, I don't believe the battery was original either. There were no color designations on the battery itself. There are small positive and negative symbols but they are difficult to see. The black unit I am referring to me is the fuse/relay that goes to the ABS backup next to the 12v battery. Regardless, shame on me for not being more thorough, and believe me when I say I learned my lesson.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    You mean the fuse box cover where the underhood jump point resides is black?
    And there is no color designations on the battery
  8. Johnny KIlo
    52
    Chicago suburbs
    yes, the battery was so dead I could not open the hatch, I was able to find the latch and release it manually but I would not expect most people to have to/be able to do it
    A
  9. Johnny KIlo
    52
    Chicago suburbs
    No, in the rear at the actual battery.
  10. Johnny KIlo
    52
    Chicago suburbs
    I like your quote BTW ed
    edthefox5 likes this.
  11. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Oh I see. I can understand how easy it could be to mess it up in the hatch. Its dark and tight and disaster prone.
    Toyota knew this so gave u the front jump points.
    Very easy. And your in the fuse box so u sure hell shouldn't be grounding anything out. And the positive has a red cover.
    I believe the majority of bad jumps happen in the hatch.
  12. edthefox5
    10,096
    4,837
    Clearwater, Florida
    The black box is the backup capacitor bank for brake power back up. Has nothing to do with the battery and there's nothing to connect a cable too so not sure the coinfusion.
    This wouldn't have happened if you used the front underhood jump points.
    Stay out of the hatch.
  13. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Simple way to remember how to connect the jumper cables correctly is to NEVER CROSS THE STREAMS. Bad things happen.
  14. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Really, a Ghostbusters reference? RIP Harold
  15. CooCooCaChoo
    962
    544
    Cow-lee-fornia
    2023 Prius
    Yes, its the easiest to remember:
    You could also go by equal sign (=)
  16. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Easy part is stay out of the hatch. Then your in the fuse box under the hood with room to maneuver and if your going at anything in that fuse box with the negative side of the jumper cable..... well.......you have no business jumping a car.
    But lots of posters swear they hooked it up right and still toasted the car so its is very important to not use a high current device like a AAA tow truck with 1000 amp capability to jump the car. The inrush current of a very dead agm coupled with unlimited donor power will greatly affect the size of your wallet. If you suspect the agm is stone dead be very weary. That can be easily be checked by tuning on the headlights. No light whatsover be afraid. Dead agm=huge inrush.
    At the very least if you must jump start using a car make sure the donor car engine is off.
  17. Marty2go
    Marty2go Junior Member
    40
    Ohio
    Four Touring
    The problem may just be it just needs a battery if it doesn't lock or unlock the doors.
