Cruise Control - Emergency Shotoff
Discussion in 'Gen 2 Prius Technical Discussion' started by Porsche998, Jun 4, 2008.
  1. Patrick Wong
    18,210
    6,517
    True, "unless the brakes are faulty..."
  2. bwilson4web
    16,533
    Then use "Plan B:"
    copyright "Speed":deadhorse:
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Well Jayman, I can see you've been drinking the cheap stuff again. :cool: That must explain all of the thinking about this topic.
    I agree with you about "the good old days" verses now. I'll take the current technology any day of the week.
    From my experience, the most likely failure mode for an ECU is a firmware glitch from sloppy programming or inadequate testing. I wouldn't expect that from a major auto company, at least not in a safety critical area. With those sort of systems we usually design-in backup and failsafe systems.
    A large EMP could be a problem. The Prius has pretty good shielding, but a big EMP is hard to stop. Now that you have me thinking about it, I'm considering a big faraday cage and mu metal shielding. I'm not sure about seeing out to steer; maybe I'll use a parascope. :D
    Tom
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Tom
    Trust me on this, as I'm an expert: after 3-4 shots, there is absolutely NO difference between that la-dee-da fancy-schmancy stuff and the cheap rotgut. If I have enough time this summer, I'll happily book a flight out your way, get two bottles (One of the cheap rotgut, one of the fancy-schmancy stuff), and we'll match shot-for-shot
    I guarantee after 7-10 shots, we'll both be passed out and your woman will probably throw you out of the house.
    Hey, I *like* that scenario. See you next week!
    Seriously though, if such an event were to occur, we'd have one hell of a lot more to worry about than whether the Prius cruise control would still work
  5. richard schumacher
    7,683
    1,066
    United States
    Then one should not be driving the car :_> And someone who is worried about multiple simultaneous failures probably should not be driving any car.
