Cruise control install and airbag light help please
Discussion in 'Generation 1 Prius Discussion' started by s9pa, Dec 18, 2011.
  1. s9pa
    s9pa It is about the environment
    28
    Midwest
    2001 Prius
    This weekend I installed Toyota cruise control kit and followed the instructions in this post.http://priuschat.com/forums/generation-1-prius-discussion/51425-2001-cruise-control-install.html
    Everything went fine, except the "enemy nut" for the stop light switch, which required a crowfoot wrench. After the install I did a test run and everything works fine, but when I was about to enter my apartment parking, the airbag light came on.
    Any suggestions about what I may have done wrong or damaged?
    P.S: I followed the instructions above to the letter,
  2. Patrick Wong
    18,210
    6,517
    Since the airbag light is on, my guess is that there is something wrong with the wiring harness connection to the driver's airbag located within the steering wheel hub.
  3. s9pa
    28
    Midwest
    2001 Prius
    The cable connecting the airbag was loose.
