Cruise control installation failed
Discussion in 'Prius v Accessories and Modifications' started by nijadmr, Aug 22, 2020.
  1. nijadmr
    nijadmr New Member
    ireland
    2013 Prius Alpha
    Hi... I hav a prius alpha 2013 (Japan) import. I tried to install a cruise control system in that. Fitted new wiring harness also but car can't detect the system. Checked with Multi meter power goes to ECU but no signal from ECU. Any suggestions will be appreciated.
  2. Ian12342
    Ian12342 New Member
    New zealand
    2012 Prius Alpha
    Hi did you ever manage to get it going I want to install cruise on my prius alpha from Japan also
