Cruise Control Issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dhman2006, Jun 4, 2013.
  1. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    I can't seem to activate cruise control on my 05 Prius. I went to the dealership and they checked the car out and said it's all good, cruise works and everything is fine, but I can't seem to activate it. Can anyone help me out please?
    Thanks.
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Hmmm, this may sound stupid but did you turn on the cruise before you tried to engage it? The cruise must be turned on every time you go into ready mode.
  3. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Yeah I turned cruise on and then push the set button downward.
  4. SmellyTofu
    SmellyTofu Average punter
    251
    29
    Sydney
    Were you driving over 40kmh? (about 45 on the Speedo?)
  5. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Make sure the Cruise lite shows on the dash and then hold the stick down for a second--longer than a than a quick flick. When you read the manuals, it doesn't say this (but do read all the manuals)!
  6. dorunron
    3,318
    1,105
    Houston, TX
    I second this one. Make certain that the light is on (Cruise) when you turn on the system. If you still have trouble after that and have read the manual then I suggest you return to the dealer and have them double check the system. If they say it is working, ask them to show you how to use it.
    About the only thing that goes bad on the cruise is the stalk switch and the clock spring. I haven't heard of any other issues except for when the inverter shuts down and disables the cruise and other things as well.
    Minimum speed to engage the US model Gen II Prius is 25 to 26 MPH. Anything less than that, the cruise will not engage.
    Hope you get it figured out.
  7. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Yeah I tried everything, nothing seems to work. I was driving on the highway at 60MPH.
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    BTW, you can't engage CC in B mode.
  9. Patrick Wong
    18,210
    6,515
    1. You need to see the CRUISE light come on, after you turn the cruise system on by pushing the button at the end of the control stick.
    2. You need to push the control stick downwards to set the speed, after you are traveling more than 25-30 mph.
    If this doesn't work, maybe there is something wrong with the switches in the control stick.
  10. ursle
    ursle Gas miser
    1,049
    192
    NH
    If the dealer ok'd it, imho, you must be putting it into b mode inadvertently.
  11. dorunron
    3,318
    1,105
    Houston, TX
    No one has mentioned this, but you might want to see if your brake lights are on all of the time. If they are, the cruise will not engage.
    kenoarto likes this.
  12. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    I tried everything mentioned on the forum and followed the instruction on the manual. Nothing seems to work. I think I have to take it to the dealer.
