Cruise control issue
Discussion in 'Generation 1 Prius Discussion' started by The Mighty Mutt, Jun 9, 2025.
  1. The Mighty Mutt
    The Mighty Mutt Junior Member
    Flagstaff, AZ - USA
    2002 Prius
    While on a longer drive last week, my car was having a really hard time maintaining the speed. It was all flat terrain and was set to 75 mph. When it would drop to 74, it would increase speed, but not by just a bit. Sometimes up to 78, 79, or 80 mph. Then it would drop down again to 74 and even 73. It would just keep hunting around in that area. I know that wasn't great for the fuel economy, but for about an hour, it was all below 25mpg. I don't know if there was something else going on that affected the fuel consumption as well as the cruise control, but that seems insanely low for uneven throttle.
    About 2 months ago, I changed the transaxle fluid. I topped it up until it spilled out the fill hole and it seems to have been fine up until now. I don't know it this has anything to do with it. It will be a few more days before I can get under there, but I want to check that it's still full and see if anyone has any other ideas as to what I could look at. Even now, on short freeway drives, the speed still hunts around on CC, so whatever it is, it wasn't just a fluke.
    Thanks everyone!
    Rob, 2002 Prius
  2. Trombone
    Trombone Active Member
    389
    130
    Allentown, Pennsylvania
    2002 Prius
  3. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
  4. Trombone
    389
    130
    2002 Prius
    dolj, while your advice is applicable in some instances, in this case the paucity of relevant hits for this gen.1 problem suggests that a wider search might produce helpful pointers or suggestions from others' experiences.
  5. The Mighty Mutt
    Flagstaff, AZ - USA
    2002 Prius
    Oh man, I'm so sorry fellas. I thought I had done a search for this issue, but it doesn't look like I did. It seems that the A/C cycling on and off can also cause this. But I think I'll take the accelerator assy. out and give a working over. After 23 years, it could probably use a good clean out anyway
  6. Trombone
    389
    130
    2002 Prius
    Yes, when the A/C compressor clutch engages, it puts a demand on the ICE, creating a drag on the engine RPMs. Since I don't do much, if any, driving with CC and A/C going at the same time, I've never noticed the surging that you've experienced. Next time I'm out on the highway I'll try to simulate the conditions and see what happens.
    In the later generations of Prius, the A/C is not belt-driven off of the ICE, but rather has an electric compressor, so I suppose those cars don't have your (our?) problem.
    #6 Trombone, Jun 14, 2025
