Cruise control issues!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DIPMODE, Apr 3, 2012.
  1. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    You may have a failed clock-spring cable. This connects the CC control stalk to the electronics in the ECU. The cable allows the steering wheel to turn and keep the controls connected.
    Try this - when pressing the button to turn on CC, also push on the stalk and move it forward. This combination of actions sometimes will work to turn the CC on. I had to put up with this for nearly a year on the 2010 before I sold it.
  2. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    I didn't read the entire thread.
    FWIW
    Some other threads have mentioned a stop light switch as being an issue with cruise.
    Plus, cruise has a minimum speed to set which I believe it is 25 mph and if you go below that speed it shuts off.
    I am new to Toyota cruise control application and IMO it is not the best.
    Good luck.
  3. priusrick
    priusrick Member
    257
    40
    Ok, button is no good on the end of the cruise control stalk. Quoting me 370 bucks to fix. That seems excessive
    SGH-M919N ?
  4. booke02
    booke02 Active Member
    391
    415
    Israel
    Depends if you are buying or selling :giggle:
  5. priusrick
    priusrick Member
    257
    40
    Okkk, typically they are not trying to rip me off at this dealership but I want to find out if this is reasonable cost for replacing a button.
    SGH-M919N ?
  6. JC91006
    16,936
    8,647
    Ebay would be a good place to get a part. If it's the same part in 2008, I have a spare to sell
  7. priusrick
    priusrick Member
    257
    40
    Part number is 8463208011 or 21
    SGH-M919N ?
  8. JC91006
    16,936
    8,647
    I have 21, for 2008. You're certain it's not the brake lamp switch right? The dealer diagnosed for you?
  9. priusrick
    priusrick Member
    257
    40
    They tested it at dealer, said all the other buttons worked except for the activate button.
    SGH-M919N ?
  10. JC91006
    16,936
    8,647
    ok. I've read about brake lamp switch failures but the cruise control switch has never been mentioned before. I guess you're the first to have this failure
