Cruise Control Limitation
Discussion in 'Prius v Main Forum' started by ahmad ashfaq, Jan 23, 2015.
  1. ahmad ashfaq
    ahmad ashfaq Junior Member
    57
    islamabad islamabad
    2011 Prius Alpha
    Is there a limit of cruise speed at 117KM/H on Prius v models ?Can it be unlocked ?
    regards
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Not in the US there isn't.
    If there is a limit, it is much higher than that.
  3. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    I have JDM, can one override it ?
  4. Easy Rider 2
    1,584
    258
    Ocala, FL
    What is JDM ??
    Details are important if you want to get good advice.
    Have you asked a Toyota dealer near you if it has a limiter on the cruise ??
  5. fuzzy1
    10,687
  6. mikefocke
    4,072
    1,857
    Sanford, NC
    Japanese Domestic Market
    ahmad ashfaq likes this.
  7. Air_Boss
    Air_Boss Senior Member
    4,244
    1,194
    New Yawk
    I haven't found one, nor have I sought to find it, but speeds well in excess of that are easily achieved, set and maintained.
  8. Alpha7
    Alpha7 New Member
    Dublin, Ireland
    2012 Prius Alpha
    For the benefit of those searching:
    Yes, our 2012 JDM Prius Alpha (7 seat wagon) seems to only allow a cruise control setting of up to 117km/h.
    On the M50 between Dublin and Belfast, it easily does 125km/h, but setting the cruise that high won’t take, and the car settles back to 117km/h. Pushing it up from there with the cruise stick has no effect either.
  9. Air_Boss
    4,244
    1,194
    New Yawk
    Well, the US spec model 2012 v Five cruise control will hold 75 mph all day long, and will increment with the cruise control stalk to “over 80 mph”. Haven’t tried to see where it tops out.
  10. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    There used to be a thriving industry in the U.K. to bring Japanese imports into MOT compliance and to remove the JDM top speed and cruise control speed limiters. Is this no longer the case?
