Cruise Control Mod (gen3)
Discussion in 'Gen 3 Prius Technical Discussion' started by GrumpyCabbie, Aug 10, 2014.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I have the UK base Prius t3 which is similar to your Prius III. Whilst it comes with front fogs it has precious little inside other than climate control. The next models up have cruise control which is mounted on the steering wheel. Well I've heard that the wiring and computers for this is there on all gen3 models (like EV mode on the US gen2 which was hidden but there) and to add cruise control to my car I'd just need to remove the blanking plate on the steering wheel, add the official buttons and new plastic plate (with a gap for the buttons) and job done.
    Does anyone know if it is this simple and whether there are other quick fixes are out there such as bluetooth telephone control (steering wheel mounted) or even just swapping the cd player with the posh one with the screen.
    52,388
    just an fyi, u.s. has cruise on a stock just below the steering wheel.
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I can tell u for certain that I did this mod on a 2012 corolla & nothing more was needed.
  4. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I thought ours was too but I don't have it. Someone had said it was possible to modify the steering wheel with very minimal parts from Toyota as the wiring was already there.
    Maybe I misunderstood them and it was just a case of adding that little stubby stalk/lever thing. Does anyone know if that's all there is to it?
    Just googled and it appears our c/c is the same as yours.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    No wiring needed. All u need is the stalk & the correct side cover. Remove the airbag, install new stalk, plug in connector, reinstall airbags & covers.
    I'll take a few pics of where the connector plugs in....this way u can verify if u have the wiring
    GrumpyCabbie likes this.
