Cruise Control not working
Discussion in 'Gen 2 Prius Main Forum' started by gptoyz, Feb 3, 2019.
  1. gptoyz
    gptoyz Junior Member
    79
    16
    los altos
    So initially the right side steering wheel controls (base model) and cruise control weren't working
    I replaced the clock spring with an ebay New (not factory) clock spring. So far so good, steering wheel controls all work but not cruise control, it doesn't power on
    I replaced the cruise control stock with an ebay New (not factory) as well but it's still not powering on
    My brake light switch definitely works
    What else could it be? I've been trying to look for a fuse for the cruise control but can't find anything
  2. JC91006
    16,488
    8,402
    Anytime you use non original electronic parts, you will have the uncertainty that it won't always work properly
    Skibob likes this.
  3. gptoyz
    79
    16
    los altos
    I did check The new clock spring for continuity as well as the the new cruise control stalk - so assuming those 2 are functioning, where should I look next?
    iPhone ?
    49,576
    ecu? not sure where it picks up the speed data. tech info.toyota.com
  5. gptoyz
    79
    16
    los altos
    shouldn't I at least be able to power on the Cruise control system at any speed? from the MFD the digital speed read out is correct
  6. bisco
    49,576
    i can't say for sure, but if something else is wrong, i doubt it matters that your speedo is working.
  7. gptoyz
    79
    16
    los altos
    quick update, I contacted the ebay seller and he replaced my clock spring with a new one and all is good. I figured it out after I checked the clock spring connectors for continuity with my multi meter
    All is good - miss cruise control!
