Cruise control question.
Discussion in 'Gen 3 Prius Main Forum' started by Mr. Blonde, Aug 18, 2015.
  1. Mendel Leisk
    42,343
    Hey, when you say your location is "Canada", I figure you're right in the middle of the word, on a map. :)
    Tideland Prius likes this.
  2. Tideland Prius
    16,680
    That would put me in Winnipeg, the geographical centre of Canada and the flattest part of the Prairies.
  3. qdllc
    qdllc Senior Member
    1,377
    400
    All the time.
    It trips the anti-lock system and diminishes braking power to the affected wheel(s).
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    Happens all the time and is well documented in PC. Has to do with the VSC (vehicle stability control) and other protection circuits that prevent over-torque of the drive shafts(s) by the electric MG's. You have to watch the road for these irregularities, or know about them in advance so you can avoid or carefully brake. I always allow a sizeable following distance between me and the car ahead just in case. It's a Prius thing.
  5. bwilson4web
    16,533
    I usually just "pat" it down if approaching a light that might change. Each "pat" reduces the speed 1 mph.
    I see no problem with holding it down except cruise control stops working under 23 mph. I am OK with braking too. As for following traffic, I drive using the rear view mirror a lot. Often I'll see some assh*le tailgater but that is something else.
    #45 bwilson4web, Oct 17, 2015
  6. bwilson4web
    16,533
    There was 'brake pause' problem we learned about in the first year. After a bit of investigation, we were able to reproduce it at will but it would surprise those not used to it. There is a Toyota patch a dealer can apply that fixes the problem.
    #46 bwilson4web, Oct 17, 2015
