Cruise Control will turn on but wont set.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Gothemtry667678, Nov 8, 2023.
  1. Gothemtry667678
    Gothemtry667678 New Member
    Myrtle Beach
    This just happened today while i was driving. I usually drive cruise control when im going a long distance but as i stated It will turn on but wont set.
  2. John March
    John March Junior Member
    32
    Winston Salem NC
    2014 Prius v wagon
    long stick wedged from your console to the gas pedal.
    Assuming no codes perhaps your driving with your foot rested on the brake?
    Otherwise, I would begin investigating the brake switch that tells the cruise control your braking. Since I have not fiddled with that part of the car perhaps someone can clear up those details on how the prius knows your braking for cruise control. I'd be curious to know if your brakes flash intermittently while driving.
    Hope these ideas help.
  3. ChapmanF
    18,964
    One could plug in a scan tool and watch the cruise control data list, to see things like:
    • is the brake pedal input being seen when it shouldn't be?
    • is the SET switch input not being seen when it should be?
    Stuff like that.
  4. Glenninmb
    Glenninmb Junior Member
    16
    I had this issue with mine and it turned out to be my clock spring in the steering wheel. They break from all the turning of the steering wheel. Mine was at 720,000 kms when it happened. Got a replacement, installed it and cruise works again.
  5. ChapmanF
    18,964
    Good outcome. (y) For others, observing the data list items suggested in #3 can help with deciding whether the same thing is likely to be the cause of their issue.
